A little frozen mud
A little frozen mud
So while I was wheeling on moday it was -7C out and every bit of water froze onto the front of my Jeep.
I found an old car sitting in an old gravel pit and figured I would drive up on it and when I went to disconnect the sway bar the light would flash but would not stay on steady. I thought right away that my dico motor was screwed like I hear so many others had but when I got home this is what I found.
Under neath the frozen mud there is a disco motor somewhere in there.
There is a winch in here somewhere too.
Then I also ripped my back bumper half off as well
I was trying to need it and my jeep just wouldnt get stuck in anything I put it through.
When I got home I had to see if it would work like that and after prying the cap off the solonoid box so I could hook up the controler it worked just fine.... Ahh the reliability of a Warn
Holy $hit! That would never happen down here, it has been mid 90's for the past two weeks! Sucks! Thankfully top down and doors off weather is moving in tonight!
man looks like you had fun.......have fun cleaning that....probably bring it in a shop overnight to thaw out, then pressure wash the crap out of it......you are going to be busy.... good job
Anyone want to start taking bets if the Disco will work afterwards?
It is fully incased in ice including the whole sway bar.
Personally I will be shocked if it works after this
Horwitz- This is why we have more alcohol in our up here.... to keep it from freezing
so true...us Canadians have real beer........My e-disco crapped out about 1 month ago....I am changing to the Currie Antirock full sway system...no more diconnecting or connecting anything.....
