Maertz's Half Ass Build Thread
#31
I ran 6 rock lights on my K5 (55w incandescent) and it was awesome. I had two in the forward wheel well pointing down and forward and out. Then by the frame, roughly under the front seats, I had a pair on each side, one pointing forward and down, one back and down. I think a similar set up would work on the JK. Looks like the frame is blocking light from getting to the middle. I wonder if mounting them inside the frame might yield better results, maybe you can mount them a little closer to the ground there to get less blockage?
#33
#34
Well another night run another messed up part. Maertz:0 Nighttime Wheeling:2
Have to fully look into it tonight, but from what ive researched and been helped with on the forum its most likely my sector shaft twisted. Will try and post up pics tonigh if I figure it all out.
#40
Nice, looks good. Did you figure out if your sector shaft was toast?
I found this thing today, and now I want;
http://www.flickr.com/photos/72867051@N00/12390526103/
JK on Rockwells. I dig the exo cage too.
