With as much as you pocketed the frame out, you shouldn't need a lot of angle on the mounting. Just make sure you cycle them with the tires on to ensure they don't rub. I got mine at around 8 degrees and probably cycled them about 50 times to get it right. Your shock angle forward to back looks good. I've always followed the rule of thumb to have the shock perpendicular to the control arms at full bump. This gives you the most consistent spring rate throughout the suspension arc.
Build is looking good. |
Maertz, thank you for having such an active thread! I've been following your build for months. I have a quick question about this if you don't mind... It looks like you have the factory cage(I didn't see any cage work on this thread), are you building your shock mounts on that? Is it only going to tie into the tub and is that okay? And if not are you going to tie into the frame and is it okay to be hard mounted to the frame AND the tub? I may be missing something or just don't understand what is okay and not okay with this big of a build so hoping for some clarification.
Originally Posted by supdoggen
(Post 3945767)
Well good day at work today! My metal came in so I can start working on reinforcing ALL of my frame mounts more, also sold my old tires, so i ordered up the rear shafts and gears. If i can get all of this done this weekend (more like 2 weekends) I will be driving and testing thereafter...
for the front, I am going with a 1350. With that much travel I found that my driveshaft angle exceeded 32*. When you measure it, you have to take the up angle of the transfer case plus the down angle of the driveshaft at total droop. I am sitting right at 36 degrees. High Angle drive line as a solution for me. I can limit my total operational angle to 35 degrees, or get their high angle driveshaft with the 1410 joint. The exhaust does play a factor so make sure you have a spacer to push out the CV joint if you have similar angles.
Originally Posted by 2climbbig
(Post 3946938)
I am runnuing 14s in the front. My front axle is stretched 2 inches. am leaving out of town tomorrow so I figured I would let the rear sit on its own springs and check my angles. Looks like I am sitting at 4.5" ride hight with 4 up and 10 down. While I have to redesign my rear link, I was able to get all the necessary data to order my drive shafts. I also got a better angle finder.
Bottom line, I don't need a high angle drive shaft as I originally thought. 32* shaft will work just fine. so I am going with 1310s on the cv and 1350 at the axle. For the rear, I will go with 1350s at the cv and 1410s at the axle. |
So, are you going to carry 3 differnt u-joints for spare parts just for driveshafts?
if anything i can see a 1350 on the cv and 1310 on the dif side, but as dirt said more parts.
Well i got to take a fellow jeeper on here (snags) from new york out and show him a little bit of what farmington has to offer. In our couple hour trip we managed to bend his drag link on just 33s and also flaten down his exhaust pipes, along with a few scratches along the way. It was a great time and i was glad to show him the area even though my rigs still down! No pictures on my end, but i know hes got some go pro footage and a few pics. It was a good getaway for yesterday, but today now i need to try and get my rig standing i cant stand not wheeling my own rig...
Surprisingly it looked alot like the evo draglink flip that was posted not to long ago.... |
