Method race wheels nv
Old Oct 20, 2014 | 01:49 PM
Rebel Ruby-Jk's Avatar
Default Method race wheels nv
Think about switching from my xd series to method race wheels nv series please post pics
Old Oct 20, 2014 | 04:22 PM
Gumbyhoss's Avatar
Default Double Standard
Not the NV, but I have the Double Standard and I love them.
ID:	580734Click image for larger version
Old Oct 20, 2014 | 06:20 PM
Tree Frog's Avatar
Again not the NV's but the Double Standards are close. The little V at the intersection of the spokes is more rounded on the NV's.
I left my center caps off as I really do not like them. Looking around at machine shops to spin me a set of hub centric rings that will be flat with the face of the rim.
I scuffed down the rings with 400 grit lightly, wiped with alcohol and sprayed urethane body color on them.
Old Oct 20, 2014 | 07:30 PM
Gumbyhoss's Avatar
Attachment 580749
Looks great. Did you tape every single one of the bolts when you sprayed the rings?
Also, I really want to drive to Oregon just to recreate your shot at Crater Lake. Nicely done.
Old Oct 20, 2014 | 07:33 PM
jkbarnett's Avatar
NV Machined
Old Oct 21, 2014 | 10:58 AM
Tree Frog's Avatar
The little bolts on the ring are threaded and come right out. In fact most are real loose.
A lot of guys recommended going to stainless due to corrosion.
After I was done with the paint work I used a Dewalt driver with the clutch backed off a bit as your threading into aluminum. Put a drop of blue Loctight on each one.
Old Oct 21, 2014 | 04:45 PM
DisasterDan's Avatar
I have some sitting waiting for 37's. Does that count?
But pulled these off google from a quick search
ID:	580912   Click image for larger version
Old Jan 14, 2015 | 05:37 PM
$iXGUN's Avatar
What backspacing are you guys running on your methods. I am looking at buying the NV's but I can only find them with 4.75 backspacing and from what I am hearing, anything over 4.5 will rub either on the controls arms or sway bar. Any insight on this would be appreciated.
Old Jan 14, 2015 | 06:09 PM
scooby snacks's Avatar
Attachment 580749
Digging the Double Standards. Was the ring black also and you scuffed it or was it machined?
Old Jan 14, 2015 | 07:11 PM
Tree Frog's Avatar
Mine were the machined ones. They are clear coated but it is real thin and I bet it would not last too long anyway.
I have seen elsewhere on the internet where guys were having the bolt heads rust pretty quickly so they were going to stainless button head caps.
As of yet I have had no corrosion at all. My Jeep does live indoors when not being driven, however it does see plenty of rain.
