NEW - IPF 920H4 JK Headlights!!
Old Nov 30, 2009 | 01:58 PM
  #51
BLK-JK23's Avatar
any idea of what the price is gonna be????!
Old Nov 30, 2009 | 02:04 PM
  #52
wayoflife's Avatar
JK-Forum Founder
not 100% sure but they will definitely be under the $200 mark.
Old Nov 30, 2009 | 02:16 PM
  #53
kinmax's Avatar
Wow, Very nice lights, you can actually see at night now.
Old Dec 1, 2009 | 03:36 AM
  #54
HappyCurmudgeon's Avatar
Eternal ***erator
Originally Posted by JKYODA
OK so after your latest post. If they are just whiter but not really brighter..... what is the point? wouldn't slapping some sylvania bulbs give you the same result for Waaaay less?
I have the silverstars in my stock headlamps, they do not have a beam like that. I suspect the reflector has far more to do with it than the wattage. either way, after driving mine stock, then with the silverstars, then seeing this, I will be one of the first ones on the list to get these. The silverstars help some for the price, but they still rely on the stock reflectors and are abysmally bad by comparrison with what i have seen here.
I need better lowbeams, i am fine for highbeams as i have driving and spot lights for that purpose, low beam is where I suffer.
Old Dec 1, 2009 | 05:30 AM
  #55
JKDinker's Avatar
Eddie, how many times did you and Cindy get high beamed driving to and from the Desert? When you have the low beams on. That's a good gauge!
  #56
wayoflife's Avatar
JK-Forum Founder
by virtue of them being whiter and with a focused beam that concentrates the light in front of you MUCH better, these lights will appear to look brighter. i was just trying to be as objective as possible in my assesment is all. when compared side by side to the "brightest point" that the factory lights put out, the brightness is about the same HOWEVER, this brightest point is concentrated in one location and in what appears to be a horizontal band across the road. everything in front of that bad or behind it looks significantly darker. by contrast, these new IPF headlights put out the SAME bright lighting and spreads it out evenly across the road. does this make sense?
Old Dec 1, 2009 | 05:33 AM
  #57
wayoflife's Avatar
JK-Forum Founder
the IPF headlight lenses are designed with cuttoffs to prevent light from unnecessarily blinding traffic in front of you. to help illuminate signs and objects on the side of the road, they are also designed with a kick up to the right. if you look at the comparison shots, you can kind of see what i'm talking about.
Old Dec 1, 2009 | 05:38 AM
  #58
JKDinker's Avatar
Actually I hadn't noticed that before. They do kick to the right from your garage photo. Nice.
Old Dec 1, 2009 | 05:45 AM
  #59
wayoflife's Avatar
JK-Forum Founder
Once again, this is a shot of the driver side factory headlight on low beam from about 10-12 ft. As you can clearly see, the beam of light is yellowish and spread out in a band or strip across the garage door and everything beneath it looks dark...
Now, compared to this shot of the passenger side headlight on low beam with the new IPF 920H4, you can see that the light is MUCH whiter and that it does a much better job of illuminating the door clear to the ground. also, you should be able to see the kick up to the right. Trust me, this does a great job of illuminating signs and pedestrians along the side of the road...
Old Dec 1, 2009 | 05:50 AM
  #60
JKDinker's Avatar
Just when I think I'm almost done, there you go again.
