New Trailer
New Trailer
Picked this up today: M1101. Lot's to do to turn it into a legit camping trailer.
The game plan is to build some marine grade storage boxes/cabinetry (using aluminum and 1/2" marine plywood) that's flush to the top of the trailer walls. I'll place them all on slides and allow for them to easily pull out to the tailgate. I'm considering have one or two small prep tables slide out (from behind the wheel well and out over the tailgate) and then swing out 45 degrees to create a cooking station (camp chef or similar).
I'll add a propane tank, small air compressor, and RV water pump with quick connects mounted to the back side of the trailer. This will allow for airing up, showering and clean up.
In an effort to reduce weight I'll likely use a tonneau cover or similar to cover it all.
The final addition will be adding tube bars mounted over the bed to allow for a trailer tent or instead of a tonneau cover possibly using a hard cover with enough strength to support 2 bodies to sleep on top with egg crate padding.
Thoughts? Anyone do a similar build?
How does the JK tow it? That thing weighs about 1500lbs doesn't it? Been thinking about getting one as general haul crap around trailer but it just seems kind of heavy.
1450 lbs. and it pulls great around town getting just under 15MPG. This trailer tracks really well and allows for short radius turns. Acceleration is still good, but I've yet to pull uphill. I'm running a 2011 JKU with the 3.8 and stock gears (for now).
I'm still calculating the added weight with the build, and plan on keeping it sub 2K.
Former Vendor
Former Vendor
