The Official " Show me your JK on 15 inch Wheels " thread
Old Aug 8, 2015 | 03:53 AM
  #531
d. gage's Avatar
Bump this up
Old Aug 29, 2015 | 03:08 PM
  #532
Dale36's Avatar
Anyone having handling issues with running 35's on 15 inch rims? Just curious.
Thank you.
Old Aug 29, 2015 | 06:21 PM
  #533
BlackRockBurner's Avatar
Originally Posted by Dale36
Anyone having handling issues with running 35's on 15 inch rims? Just curious. Thank you.
I can come into a corner hot, scrub brakes late, hit the apex and exit full throttle pulling close to a full g. Just not in a jeep. There's no issues with 35's on 15's. If one decides to roll the tires on a lifted rig with high center of gravity, the issue isn't mechanical.
Old Aug 29, 2015 | 07:15 PM
  #534
orangedude71's Avatar
15s 35s on the Rubicon
Old Aug 30, 2015 | 06:38 AM
  #535
Dale36's Avatar
Alright then Thank you. I shall assume many are using an 8" wide wheel with 12.5" wide 15's without issue as well. I think the 15x10 wheels run more of a risk losing a bead.
Just planning for my next set of tires and wheels...
Old Aug 31, 2015 | 06:24 AM
  #536
JurassicJeep's Avatar
Alright then Thank you. I shall assume many are using an 8" wide wheel with 12.5" wide 15's without issue as well. I think the 15x10 wheels run more of a risk losing a bead. Just planning for my next set of tires and wheels...
I've run 15x10 wheels at 13-15 PSI with no issues for years (3 different Jeeps) and we do a lot of rock crawling like the Rubicon. We've been running Goodyear MT/R 35x12.5R15 's on the ProComp steel wheels for the past 2 years.
Old Sep 1, 2015 | 07:29 PM
  #537
Dale36's Avatar
Why the 15x10 and not 15x8? Just curious.
Thx
Old Sep 2, 2015 | 06:21 AM
  #538
Why the 15x10 and not 15x8? Just curious. Thx
Wider stance for more stability...
ID:	623508   Click image for larger version
Old Sep 2, 2015 | 06:45 PM
  #539
Dale36's Avatar
Understandable. Thank you. Here in Colorado, the trails can get very narrow even for a regular width Jk...narrower tends to be better here.
Old Sep 2, 2015 | 07:26 PM
  #540
Blue's Avatar
I used to run full sized Broncos until I converted to the JK. I always ran 15x8 and 15x10 wheels on those rigs. I never had issues running 32s, 33s or 35s on them. Those things are heavier than a JK and a little bit wider. I have 3 worn out Broncos in the yard with about 750,000 combined miles among an '81, '86 and a '90. Bronco guys running bigger wheels generally converted to 8 lug axles.
