OME Lift installed
Old Jul 15, 2011 | 02:33 AM
  #21
blackpanther's Avatar
Originally Posted by fanatic
I havent replaced the shocks yet, but I will run the OME shocks also, just need to recover from buying the Jeep, wheels, tires, and springs in a 2 week period.
Did You Install the spacers up front?
Old Jul 15, 2011 | 09:19 PM
  #22
fanatic's Avatar
yes it has the spacers up front
Old Jul 16, 2011 | 03:45 AM
  #23
lopezv123's Avatar
Originally Posted by Hammer002
OME = Old Man Emu. Not OEM. And I looked into the same thing you said. The lifts are considered a "performace accessory" which is not covered under warranty. ANd the 2 inch is nothing more than a Rubicon Express with Mopar labels and the 3 inch is a Superlift.
Edit: lol ^^ fanatic beat me to it
Oh and Fanatic - the OME lifts are said to actually lift to 3+ inches. Its the same one I am looking at for phase II. This is over the 2.5 inches recommended max lift for not replacing drive shafts due to new angles. Just something to think about and maybe look into...
And but the way, LOVE that new tan color. Great looking Jeep.
I have the OME HD setup and ended up with 2.5" of lift when first installed (measured from center of hubs). After a few hundred miles the lift settled to 2" all the way around and I am not running a spacer in the front. Great setup for an expedition rig (which is what I wanted).
Love the tan color as well ! Jeep looks great! Congrats!
Old Jul 16, 2011 | 05:58 AM
  #24
Well mine did not come with them.
We did 2 JK'S one 2007 and mine 2009 same set up mine has a rake and the 07 does not go figure
Old Jul 16, 2011 | 06:13 AM
  #25
single's Avatar
Did you do the lift yourself? Just curious. I've got an OME lift on its way and was curious as to the installation time.
Old Jul 16, 2011 | 08:55 AM
  #26
fanatic's Avatar
Mine didnt come with them either, I just figured Id want them. The install is pretty straight forward, just replacing springs. It took us a couple hrs to lift and mount and balance 5 tires.
Old Jul 16, 2011 | 09:44 AM
  #27
single's Avatar
I got the LT lift kit with JKS Front and Rear Trackbars, long travel shocks, adjustable swaybar links, bump stop extensions, extended brake lines and adjustable front lower control arms.
Old Jul 16, 2011 | 10:11 AM
  #28
fanatic's Avatar
I just bought springs and spacers. I will install shock extensions soon. The alignment was still good, just had to set the toe. I may do adjustable track bars but it drives fine and if the axles are off center its not much.
Old Jul 16, 2011 | 11:23 AM
  #29
single's Avatar
I started to get that one, then got to thinking I wanted to go to 35's when my 33's wear out. Decided to go ahead and get the LT kit and just do the lift once (I hope).
Old Jul 17, 2011 | 05:37 PM
  #30
Actually we were aboutto do the lift ourselves,but my buddy came across a shop that only dealt with jeeps,
So the price he was charging us was too good to refuse.
He installed the coils shocks,steering damper,front and rear adjustable trac bars for
.......320.00 Cdn.
