I just got a set of 295/70R 17 Toyo Open County M/T put on my '07 Rubicon. I experienced minor rubbing at FULL turn with the stock rims. After installing 1.5" wheel spacers the tires no longer rub - no mods to my suspension. The tires are amazingly quiet and aggressive looking. I'm thankful I saw this thread before I made the investment - otherwise I wouldn't have been satisfied.
Originally Posted by BS07Rubicon
(Post 2499080)
I currently have a stock JKU and I am looking at buying a set of Nitto Trail Grapplers 295/70/17. First off, does anyone have a tread lift estimate on these? I'd like to make sure I'm not getting into some tires that will only last 30k miles. Also, since I'm running stock wheels, I was wondering if these tires could be installed without spacers. I'd like to try them first wo, and then if there is rubbing I'd throw on a set of spacers. I know a lot of shops won't install tires onto a rig with spacers, so I want to make sure I can have them installed and then see if the spacers are needed.
Any input is appreciated. |
Originally Posted by timandre22185
(Post 2503612)
You're going to either need the spacers, or you'll need to adjust your steering stops. (See the Write-ups section at Project-JK on how to do this.) |
Would I be able to have the tires installed at a discount tire and then make it home and either adjust the steering stops or put on some spacers? Would they install that size of a tire or would they have issues?
(Post 2503653)
If they won't install the tires on your Jeep, the other option is to see if they will install the tires on the wheels themselves and you just mount them on your Jeep yourself. :dontknow2: |
Thanks to this thread and a few others I have finally decided to go with the AEV 2" lift and the Toyo 295/70R17 tires. I Did the 2.5" lift and 35's on my 2007 and wanted to go a little smaller since the Jeep is my DD.
Going back to a stock Jeep has been tough. LOVE the added power but I still have trouble getting out of it, I fall up.:D |
5 Attachment(s)
Attachment 207205Attachment 207204Attachment 207206Attachment 207207Attachment 207208
Someone asked for the pics... 2007 Wrangler Rubicon w/ stock suspension. 295/70r17 Toyo Open County M/T with 1.5" wheel spacers. |
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=207205"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=207204"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=207206"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=207207"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=207208"/>
(Post 2514414)
