Pics of 295/70/R17 Tires? Badass IMO
You say you should have stopped with 295s? Why do you say that? MPGs not great on 37s?
Might as well add mine to the collection. 295/70/17 Toyo MT's on a Teraflex Leveling Kit w/ Spidertrax wheel spacers.
And comparing it to the stock Rubi tire:
Thanks. The Leveling Kit is from Teraflex. Here's their description:
This leveling kit adds 2" to the front and 1" to the rear, effectively leveling the 2 or 4 door's factory rake stance. The kit comes with front sway bar links. You can run a 33-34" tall tire with this kit. If you prefer to run the factory wheels, you may need wheel spacers for proper clearance. Fits 2007+ newer Wrangler and Unlimited models.
Here's the link to the product on the Northridge site:
http://www.northridge4x4.com/proddet...rod=TF-1155200
Basically, its an inexpensive spacer lift option to run up to a 34" tire (without messing around with any other parts on your JK that can happen when you start to lift higher). Works great!
JKs come from the factory with a rake to the front. A leveling kit consists of coil spacers or springs that bring the front to be level with the rear while at the same time raising both a bit.
Here is the TeraFlex spacer leveling kit and here is the coil spring version.
On edit: Looks like Merlin beat me to it. lol
Also, are the springs a better solution vs the spacers?
