Post Your 22 Inch Wheels
I am currently in build stage and am going with 22" Fuel Crush wheels with 37" Toyo OC R/Ts. I was going with 20's until I saw a Jeep (pic attached) with 22's on 37's and that was it, I had to have it. No need for the negative post I just want to see pics of others with 22's. Prefer with AT/MT's but heck even some low profiles look good too.
Completely out of sorts for me because I'm not usually that guy.
But
22's on a Jeep? Really? I certainly hope you didn't expect to not get flamed....because....good luck! Might as well lower it and throw some 13" Daytons on it. Same difference. 22" wheels, 37" tires with virtually NO sidewall....what are you ever going to do with that? Sure as hell aint gonna take it off road! And since that's the case, you might as well not spend money on a decent lift that's more or less never going to get used. So just throw the 4 Wheel Parts catalog at it and call it done. And make sure you throw dual 50" lightbars across the windshield, too. And if you expect to be taken seriously with your post.....um.....you're an idiot. Why not throw those 22's on an eighties model Buick instead? Seriously....if you're really wanting to run 22" wheels and 37's....trade your Jeep in for a 3/4 ton crew cab long bed truck. At least then you wont look like as big of a tool.
Good luck with your mall crawler.
But
So allow me if you will (not that you really have a choice) to inject some constructive info into my response.
Your choice of tires, although way too large in rim size, is at least a good one. Ran the Open Country RT's on my '14 ram for about 25000 miles and had no complaints. They wear good if you keep them rotated and are pretty quiet on the asphalt. Decent traction when you need it and not too aggressive. A good mix beween an MT and an AT tire.
Now if you insist on running 37's, especially with 22" wheels....please make sure you at least add a truss kit to your front axle, whether you decideto try and wheel it or not. And be prepared to replace the craptastic OEM ball joints soon after you go to larger wheels & tires. The shitty nylon insert inside them will wear out extremely fast and they're not serviceable. So either spend $250 on Synergy ball joints that at least have grease zerks and sintered metal inserts, or pony up for the rebuildable DynaTrac ones that run about $500. Also, make sure you replace the OEM track bar, drag link, and tie rod with something beefier. I personally run a Rock Krawler adjustable track bar and Synergy tie rod & drag link. The Synergy tie rod uses 1 ton TRE's which you'll definitley want for running those wheels and tires.
Again.....good luck and hope it's everything you expect.
Thanks man, not looking for recognition just wanted to see other Jeeps with similar set ups. Thanks for the advise on the Synergy Ball Joints, I actually already ordered them and the truss kit for the D30. It all should be here by the time the entire lift gets shipped. Set up should be just fine with how I will use the Jeep.
Here's another one I found 22/37's
I read your post and don't have any images to share. But I do have some relevant info. JK-Forum is more about rock crawling, with a strong expedition/overlanding contingent. 22" wheels are not very suitable for either of those pursuits. You may as well have posted in a knitting forum for pictures of Jeeps with 22" wheels as posting here. Not trying to seem rude, just be honest with you.
