programming
Yes, an AEV Procal can help with that. If you have an auto trans, by calibrating your new tire size with the Procal this will make your speedometer & odometer give a more accurate reading and allow your trans to shift properly...
If you have a manual trans, you can still benefit from the Procal by calibrating your speedo & odo, plus it has some other added features (TPMS, tire size changes, idle setting, gearing, etc)
