programming
Old Jan 22, 2013 | 09:00 AM
txboggers's Avatar
Default programming
will I have to program my 2012 jk once I put my 37's and 4 inch lift on?
Old Jan 22, 2013 | 09:07 AM
aldaman's Avatar
Yes, an AEV Procal can help with that. If you have an auto trans, by calibrating your new tire size with the Procal this will make your speedometer & odometer give a more accurate reading and allow your trans to shift properly...
Old Jan 22, 2013 | 09:11 AM
aldaman's Avatar
If you have a manual trans, you can still benefit from the Procal by calibrating your speedo & odo, plus it has some other added features (TPMS, tire size changes, idle setting, gearing, etc)
Old Jan 22, 2013 | 09:42 AM
txboggers's Avatar
Originally Posted by aldaman
If you have a manual trans, you can still benefit from the Procal by calibrating your speedo & odo, plus it has some other added features (TPMS, tire size changes, idle setting, etc)
so yes I have to?
Old Jan 22, 2013 | 10:04 AM
aldaman's Avatar
Originally Posted by txboggers
so yes I have to?
No, it's not a " must have to" but for me I just want the added insurance/piece of mind that everything is in sync knowing that my tire size, speedometer, odometer and auto trans are all on the same page
Old Jan 22, 2013 | 10:37 AM
txboggers's Avatar
alright because I have a manual and wanted to know if I need to
