Quick Disco Before & After
Teraflex are around 99 and JKS are around 130. I haven't installed the teraflex but the JKS are a snap to install.
The Teraflex disco's are really easy...unbolt the factory links and bolt on the Teraflex's basically. One advantage to the Teraflex is the bracket that bolts to the body mount that lets you pin the link up and out of the way without having to use bungee cords to keep the sway bar from hitting something....that, and they're cheaper.
It looks like when you disco the sway and move it to the body mount it's lifted up. Does that rub the tire? I've heard a lot of problems with the sway pointing up and rubbing when you're articulated.
mine doesn't....but with my backspacing (4"), my wheels are pushed out a little so maybe that helps
