Rock Krawler 3.5" X-Factor Plus...and eventually long term test
Old Oct 5, 2009 | 07:24 PM
  #41
Stuka's Avatar
I am very curious as to why it uses a 3 link in back, as to me their are more downsides than upsides when compared to a 4 link.
But it looks like a quality kit otherwise.
Old Oct 5, 2009 | 08:15 PM
  #42
ROKN JK's Avatar
Originally Posted by BLKRUBI
I see them now, thanks. Got 3.5" flex system on the way!
Excellent...keep me posted on how the install goes....and how it works! If you lived closer, I'd come by and lend a hand..
Old Oct 5, 2009 | 08:20 PM
  #43
ROKN JK's Avatar
Originally Posted by mattb2179
I love RK kits! VERY SWEET!
Thanks bud...I love it too....
Of course, my rr DS bit the dust shortly after the install and the CV boot on the front is now leaking so it is at ORE as we speak having them replaced! I wasn't surprised at all since the angle on the rear ds is so extreme with that much lift!
Old Oct 5, 2009 | 08:22 PM
  #44
ROKN JK's Avatar
Hey Stuka...what do you see as downsides? As you can see, it articulates very well, and no bind! To me the geometry makes a lot of sense and just lets it move easier! Maybe RK will chime in with a more technical answer....
Old Oct 6, 2009 | 09:50 AM
  #45
john smack's Avatar
I will be upgrading to a RK lift very soon!
Old Oct 6, 2009 | 03:11 PM
  #46
ROKN JK's Avatar
Originally Posted by G.I.JOE¤MFA¤
The Independent Three Link has been proven as the best suspension design for high articulation demands while maintaining precise street control.
even the Triple Threat system uses a 3 link in the rear. "extremely flexy independent 3 link for extreme trail use!" its a 4 link front that you can remove 1 link and convert it to a 3 link front.
What he said!
  #47
ROKN JK's Avatar
Excellent, John...keep us posted...and don't forget the pictures!
Old Oct 7, 2009 | 03:20 AM
  #48
08leocon's Avatar
Originally Posted by 08redJKnCA
Hello all,
I recently installed the RK 3.5" X-Factor Plus kit and want to pass on the info. If you aren't familiar with Rock Krawler's products, I can tell you they are on the beefy side! They use solid control arms instead of hollow tubes. I guess they would also make a great weapon prior to installation! Not that I would know!
Troy (iadventure) and I did the install and of course we were so excited, we forgot to take pics until one end was almost done...but we did take pics of the parts installed...
How many of y'all can relate to this view?
This shot gives you a look at the rear track bar bracket. The 3.5 kit does not include a front track bar bracket, just a rear. The sway bar mount is removed because it is relocated back an inch to align it with the axle which is also moved back an inch by the longer control arms...(not sure how long the driveshaft is going to last now..but that's why there is an aftermarket)...
This kit includes new brake lines and here is the bracket to attach it to the frame...
One of the things that sets this lift apart is the 3 link rearend. This shows the massive truss which gets welded to the rear axle (thanks Mel)...also notice the included very stout adjustable rear track bar...
I opted to use Mel's Rock Stars in lieu of RK's shock relocation bracket since I know how I wheel and I will definitely need the skid plates the Rock Stars provide! The Rock Stars also give you more clearance in the back since part of the control arm bracket is cut off.
This pic shows the bracket which gets welded to the frame (thanks again Mel) to mount the other end of the one rear upper control arm...If you ever decide to switch to a long arm kit, the bracket stays and you use different mounting holes.
This shot shows the other side of the truss and the connection of the control arm...
How about a front lower control arm mount? Did I mention that RK give a lifetime "abuse proof" warranty on all of their hard parts...beat that!
Here are a few pics of the included front sway bar discos...
The mounting of the included adjustable front track bar...
A found out a few things....some the hard way. The heavy duty truss tends to interfere with the standard mounting location for Woods' evap relocation kit. One bump after leaving Mel's shop and it was toast...$43 later, I have it mounted farther forward so it won't get hit again. Do NOT overlook the installation of the included front spring hold downs! I did and had the spring pop out on the maiden voyage. It bent the heck out of my Woods steering stabilizer relocation bracket (yes the parts I got from Brett aren't working out so much for me lately...but that's not his fault). We were able to get the spring back in place without too much trouble thanks to the incredible articulation of this system. The shocks you see are the Bilstein 5100s. The rear shocks are for the 0-2" lifts and the fronts are for the 3-5" lift since the rear shocks mounting points are relocated up 2 inches (also the case with Mel's Rock Stars).
Obligatory poser shot:
As you can see...this system does flex!
And a run just isn't complete unless I get on 3 wheels at least once...
Since this picture was taken, I have added the RK Drag Link (the stock one was bent). I have also removed the steering stabilizer and ordered a kit from ORO which mounts it between the frame and the drag link...more to come on that...
Please feel free to ask any questions you may have. I am super stoked with this kit and the amount of lift it gave me (about 5" in the front and about 4" in the back). It sits very level now...and actually went up an inch in the back when I took off the rear bumper and spare carrier. I have no concerns about clearing 37's (once I get a non-dana 30 in the front). The install was very straight forward and they actually give you a 20 PAGE instruction manual (installers of other kits know how unsatisfactory some instructions can be). Chris and Jeremy at Rock Krawler are the best and will take all the time you need to help out any way they can. I am VERY satisfied with my purchase experience!
FTF as time goes on and I get more experience with the kit!
Happy wheeling!
Allan
PS...special thanks to Troy for most all of the included pics....
Awesome
Old Oct 7, 2009 | 07:04 AM
  #49
ROKN JK's Avatar
Thanks 08leocon...I can't wait to "test" it some more! anything for the cause!
Old Oct 7, 2009 | 08:40 AM
  #50
09mjpkm's Avatar
looks like that lift is treating you good
