Rubicrawler installed
Old Feb 7, 2011 | 04:39 AM
  #31
Muffins's Avatar
How is the Rubicrawler compared to a complete Atlas transfer case? I'm guessing the Atlas just give you more and lower gearing choices but with a more difficult install? Has anyone here had experience with both?
Old Feb 7, 2011 | 03:36 PM
  #32
02blujpx's Avatar
Originally Posted by SLVR07
Hey 02blujpx I will have to look and refresh my memory....I think the one you are talking about is at the t case....and I think I reused it when I hooked everything back up.
Yea that's the clip I was reffering to.
Old Feb 7, 2011 | 03:49 PM
  #33
boots's Avatar
Originally Posted by 4LCKD10RUBIUNLTD
I like that stock look. Was it hard to do? I think I will try this when Its my turn to do a Rubicrawler.
No, this was super simple. The stock knob just pushes on (it's NOT threaded). All I did was match the thread size to the stick and ran a tap down inside the knob as far as I could. No drilling at all just ran the tap down inside the knob.
If I remember right the shifter knob from Mopar was like $13......
Old Feb 7, 2011 | 03:59 PM
  #34
boots's Avatar
Originally Posted by MSUConrad
I like those knobs as well. Can you post a top down pic? I'd like to see the clearance between the two.
I don't have a photo of the shifter knobs from the top down right now. The clearance is about one inch, maybe a inch and a eighth. I know it does'nt sound like much, but I have had no issues shifting it at all todate.
My first day off is Thur. will try to post a photo then.
Old Feb 18, 2011 | 11:36 AM
  #35
Deepwater's Avatar
Originally Posted by 02blujpx
This may be a dumb question,but does this also fix the stupid plastic clip with the T-case? thanks
No it doesn't. Reuses the transfer case shift cable. I used a 3/16" "E" clip and a washer after grinding off the plastic clip on the shift cable end. I got the clip in a variety pack of them at Kragen Auto.
This is the time to put in that fix as you have access.
Mike
Old Feb 18, 2011 | 12:02 PM
  #36
Deepwater's Avatar
Originally Posted by MikeReo
I really want one of these. under 2k?
Yes, signup for their email notices. Last year they had limited time discounts. I got mine with the control module which is very worth while on a Rubicon, the shifter kit and 4 quarts of tranny fluid and a trans filter for a little over $1800. If you go with the standard shifter setup you can save a 100 bucks. I didn't use the filter after all, too lazy to pull the trans pan and dump the rest of the fluid. Still needed the fluid though.
Absolutely love it. It has really exceeded what I expected from it. In low low 2nd gear it is so much smoother crawling over big rocks. I cruise the trails in 2w rubi low which is just right and I can disconnect my electronic sway bar and lock my lockers if I want.
Mike
Old Feb 18, 2011 | 12:11 PM
  #37
Pluke the 2's Avatar
doesnt four low in the 1st gear do the same thing?
Old Feb 18, 2011 | 02:56 PM
  #38
jesse0376's Avatar
Not even close
Old Feb 21, 2011 | 01:52 AM
  #39
Sarathesahara's Avatar
I purchased the rubicrawler from advanced adapters and installed in eight hours with hand tools only. Everything I needed came in the kit. The worst part was removing the tail shaft from the tranny. It was tight and you must have a good slide hammer. The interior required no modifications to the consol. Everything fit perfectly and I had no problems with hole allignment etc.
What kind of work area did you have? Shop or garage or yard?
Old Feb 21, 2011 | 01:55 AM
  #40
Nice I like the factory look! I put a sprint booster in about 2 weeks ago....it does not feel like the same motor I was impressed and it is so much more fun to drive....do you know what clip 02blujpx is referring to?
What does the sprint booster help with?
