salvaged Dana 60's - JK brackets?
Old Jan 23, 2009 | 03:59 PM
Default salvaged Dana 60's - JK brackets?
Does any maufacturer sell JK mounting brackets that could be welded onto a salvaged dana 60? Has anyone done the match on how much it would cost to build up a used dana 60 compared to buying a new one?
As always, thanks for the input.
Old Jan 23, 2009 | 04:06 PM
Piginajeep's Avatar
teraflex has a set
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/teraflex-jk-axle-bracket-kit-69823/
You may be able to buy a set from Solid axle as well
Old Jan 23, 2009 | 04:07 PM
Piginajeep's Avatar
whats your plans for the esp? thats the big issue.
JK07's Avatar
contact SOLID Axles they should be able to send you alll the JK brackets for 60s. they have plenty of them in stock.
Old Jan 23, 2009 | 04:24 PM
greenmachine07's Avatar
i agree. id hate to see you get so far and than have a light constantly coming on
Old Jan 23, 2009 | 04:45 PM
Good point on the ESP. I guess I dont understand how it would interact with an axle upgrade like this. What would be the issues?
Old Jan 23, 2009 | 04:54 PM
Piginajeep's Avatar
You wouldnt have any ESP or BAS control. Unless you have the program shut off, I'm sure it would mess with your computer system if you didnt
the sensors plug into the wheel bearings.
Old Jan 23, 2009 | 05:03 PM
David @ Currie Ent.'s Avatar
Former Vendor
If you are interested in putting your own 60 together we have everything you need.
Axle Shafts
http://www.currieenterprises.com/CES...6.aspx?id=3371
Mfg: CE-1014PJK
Our Price: $599.95
Description: This is the complete 35 spline Extreme Duty axle package for the '07 and up Jeep JK Wrangler. Includes the forged alloy axle shafts, ABS tone rings, wheel studs, JK axle bearing retainer plates, Set 80 axle bearings, races, seals, and retaining collars. For this price these axles are supplied cut and splined to fit our RockJock JK rearend unit - or - custom cut and splined for those buying our housing ends and making their own housings. Available in 35 spline only. Sold as a kit.
Housing Ends
http://www.currieenterprises.com/CES...E.aspx?id=3119
Part #: CE-95011JK
Our Price: $129.95
Description: This is the new heavy duty housing end used on all Currie RockJock® JK rearends. Welds to the tube, accepts a set 80 wheel bearing, and is designed to allow the retention of the factory JK disc brakes. For use on the right or left side. Sold each.
Brackets
http://www.currieenterprises.com/ces...316&p=399.9500
Mfg: JK-BRKT-R
Our Price: $399.95
Description: This is the Currie heavy duty rear suspension bracket set for the '07 and up Jeep JK. Sold each.
Old Jan 23, 2009 | 05:15 PM
Piginajeep's Avatar
sorry forgot about Currie
You guys have this figured out!
Old Jan 23, 2009 | 05:18 PM
bigbluejk's Avatar
there you go! make sure you take photos, and keep us up to date on progress!
