Show off your shift knobs!
Old Jan 15, 2014 | 06:27 PM
  #281
Bright Lightning's Avatar
Default Van Chase Punchy Skul Shifter Knob
Just got this knob from Ebay. I knew they sold it at pepboys and advance auto parts but I wanted it in a whiteish color to go with my Bright White JK not green or black or some other bright a$$ color. I think it's pretty F'n sweet!! It didn't have any adapter just a 3/16's pilot hole, so i just drilled it out with a 5/8's bit and then cut a piece of 5/8's PVC tubing to fit into the flat area of the shifter shaft and then jammed it the hell down on there. Perfect fit!!! No epoxy or glue necessary!!
Old Jan 15, 2014 | 06:54 PM
  #282
stoova's Avatar
Originally Posted by deepjeep13
Hurst shift knob. Still unsure what to do for the 4x4
l
Is that a 3 prong outlet I see over there ?
Old Jan 15, 2014 | 06:55 PM
  #283
stoova's Avatar
Originally Posted by mattyk
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=413506"/> this is what im running. love this thing!
Whered u get that
Old Apr 20, 2014 | 07:56 PM
  #284
afpilot82's Avatar
JK-Forum Ambassador
Finally fabbed up and installed my cyclic grip.
Old Apr 20, 2014 | 08:49 PM
  #285
JK-USMarine's Avatar
Pineapple grenade.
Old Apr 21, 2014 | 03:03 PM
  #286
stangmike1's Avatar
Rugged ridge knob painted the numbers yellow to match the jeep
Old Apr 21, 2014 | 03:26 PM
  #287
Monte417's Avatar
Here's mine
Old Apr 21, 2014 | 03:32 PM
  #288
GP13SU's Avatar
Originally Posted by Monte417
Here's mine
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=547437"/>
How did you make that work? Do you have an adapter to make it threaded?
Old Apr 22, 2014 | 02:38 AM
  #289
jdk's Avatar
jdk
Here is mine
Old Apr 22, 2014 | 05:33 AM
  #290
Monte417's Avatar
I had to make an adapter using a locknut and bolt. Found a bolt at the hardware store that screwed into the shifter. Then I got a locknut that fit the bolt. I cut the bolt sorter but long enough so I can screw it halfway into the locknut and fully screwed into the handle on the other end. I then filled the nut up with jb weld and stuck it on the stick shift
