Show and Tell: Rock Krawler Style
#582
So I'm upgrading from the 2.5 flex to the 3.5 X-factor tomorrow - do I need to move the tear swaybar mount back? Will I have an issue?
Since I am upgrading, I didn't get any bolts or anything to move it? Or instructions that tells me that I have to?
Thanks for your help!
Scott
Scott
#583
So I'm upgrading from the 2.5 flex to the 3.5 X-factor tomorrow - do I need to move the tear swaybar mount back? Will I have an issue? Since I am upgrading, I didn't get any bolts or anything to move it? Or instructions that tells me that I have to? Thanks for your help! Scott
#586
#587
here are the instructions that came with my 3.5 X-factor. Has bolt size and install info. I realize you don't have the kit and you are upgrading, I was just letting you know what the kit has and wants. You could probably find a set of 3/8 self taping thread bolts at fastenal or tractor supply.
#588
#589
I started building a jig to torque down the RK jam nuts to the 250-300lbs. It's from leftover scrap I had so this is what I came up with. Hole sawed two size holes for the different upper & lowers joints to be clamped by the body so I can keep them inline.
#590
You're a genius. I'm definitely copying this!
