Show Your "whoops" Stuck Pix
#31
went through this same spot 3 times prior... then it just gave out... like there was just a hole under the top of the mud... got a nice little suction to it.. broke two tow straps and then took a tractor 3 tries to get me out..
here's where the tractor dug down
#32
Got hung up on a tree... not nearly as bad as the other guy...but I feel his pain!
Then got high centered about an hour later in a mud hole... don't have pics of that one though...
#33
#36
I have no trouble believing you... I have been through some pretty similar stuff. They are strange tires... sometimes they surprise me, but most of the time they are useless. It's amazing what a little momentum can do. Usually I will play in the mud in 2wd then pull myself out in 4wd when i get stuck... that time it just didn't work.
#39
Was motoring across an ice area, thought I was pretty safe, since Ice was pretty thick in general. To be save, went closer to the edge. Unfortunately, didn't consider the heat of decomposition thinning the ice..probably should have went through the middle. Darn bog ice.
#40
