SimpleOrange Build Obsession!!!
#41
#43
so here is the start to the trail doors im designing each door will be two pieces. im using the 4x inovative latches and building my own hinges, everything will be laser cut. Im going to dimple die the large 3" holes on the insert and the medium 1.5" around the frame, the frame will have a hex mesh cut into it and powder coated black the insert will be body color, and will be bolted together with stainless hex flat head bolts. i still may change the design a bit once i finish the front doors
autocad drawing to scale
dont make fun of my model lol jk if you want to!!
a better picture of the mesh
#45
That's a sweet ride, dude. How about a quick how to on the inside of the hard top? I really want to do that. Does it make it crazy hotter in the cabin?
#46
#47
Originally Posted by simpleorange
I used red scotch bright pads taped the side windows with green painted tape because I have aftermarket tint. I removed the rear window and related hardware and used prepall wax and grease remover before spraying it with the dupli-color truck bed coating it took about 10 cans to cover well do not use the roll on kit, it will have a very uneven texture. I let my top sit for 3 weeks to air out. I can't tell a difference in temp. It really changed the whole feel of the interior!!!
Again, your JK is SWEET!
#48
awesome job man .. nice write up .. very creative, nice work. yeah i agree with other people you need to sell those grill inserts.. best ive seen.
#49
#50
i noticed that your fenders are same color did you chop the factory ones and glue or connect them somehow to the metal ones or how did you do it ?? i love the black with orange and how everything is arranged !
