Steering wheel not aligned???
I got a 13 sahara jku with aev 3.5" lift and the steering wheel is not straight. I saw on here how I can adjust the steering wheel so its straight but I can't find it. Any help on how to do it. I heard its just a bolt that needs to B tightened or loosened??
Sent from my dumbphone
That video is accurate in my experience. Gives useful advice which way to rotate the drag link to get the right result. You will need to drive it after adjustment to see if it is right as eyeballing it doesn't work. Don't forget to torque the drag link bolts when you are done.
There is a tie rod end and has 2 threaded ends with a 2 bolts, losing it. Get the steering wheel straight, and drive back and fourth without turning the steering wheel, and repeat until its straight. Just turn the piece left or right, remember a few turns is a huge difference, so double check how much it turned. Hope this helps.
