Strengthening stock drag link end
Old 07-25-2011, 08:24 AM
  #51
BuckLisa's Avatar
Originally Posted by Ryanc
Unless you have a rock krawler tie rod.
I should had made myself clear; for the OEM tie rod only. BTW, the Rock Krawler Tie Rod uses the stock tre end for the stock drag link. If that is the case, why can't you use the Moog ES3624 made for that????? This part is made for the stock drag link which should work with the RK tie rod.
Old 07-28-2011, 08:19 AM
  #52
The_Yeti's Avatar
does anyone on here have a pic of the Rock Krawler draglink flipped? it seems that i should be able to run the Rock Krawler tie rod and drag link and just buy 5 moog ends(keep 1 as a spare) I picked up one for my stock drag link but if/when the stock draglink goes bad on the knuckle end this seems like a smart idea.
Old 07-28-2011, 08:49 AM
  #53
river2c's Avatar
with Moog ES3624 ends
Old 07-28-2011, 08:51 AM
  #54
The_Yeti's Avatar
awesomeness! Thanks for the photo.
I keep hearing things about Currie breaking and rusting. but i like tidea of using the same ends and keepin a spare.
do you have any issues with the strait drag link. i know most are curved.
Old 08-02-2011, 08:33 AM
  #55
The_Yeti's Avatar
i ordered a replacement end for my draglink ES3624 it is not greasable. it came with a zerk but the end has no place to put in a zerk. or grease it at all. did they shipme the wrong part?
Edit:
called Moog they said Amazon has been shipping out the wrong part lately. and this is available from any o'riley or advanced auto with lLimited Lifetime Warranty from authorized dealers. not ebay/amazon
Old 08-17-2011, 09:30 AM
  #56
rdubb1031's Avatar
do you have a picture of the other end as well? do you need to do anything else besides swap the ends? I'm looking at the currie TRE and DL kit and would like to do the same..
does anyone recommend I touch anything else while doing this? the reason I ask is that I just got told both my TL and TRE are shot at teh passenger side.. lots of slop.. might as well upgrade everything at once.. thoughts?? recommendations??
Quick Reply: Strengthening stock drag link end
