Tiki Build
Old 12-30-2014, 03:09 PM
  #41
Pats fan's Avatar
Originally Posted by winkelhawk
Finally getting some more things done to the Jeep. Just installed Method Racing D105 Beadlocks, and Nitto Trail Grapplers 35's. Just waiting on the rest of my lift to come in to install it and get the 4:88's installed.
Attachment 589504
is there a lot of tire rub with this setup?
looks good btw.
Old 12-31-2014, 02:53 PM
  #42
winkelhawk's Avatar
I haven't taken it off road yet so not sure. The Rancho kit only came with the front bump stops, pretty sure it will rub pretty good without any rear bump stop. I think the front will be OK. I am going to measure what I need next week. I just swapped out the rear spring spacers today for 2" Icon coils, it raised the back up about 1/2". I also added a Synergy rear track bar.
Old 01-18-2015, 12:01 PM
  #43
winkelhawk's Avatar
I finally got some time to install the coilovers and rear resi shocks. I still need to lower the front end, install the correct length bumpstops, add new swaybar links, and make a brake line bracket. It drives completely different now, it is a great ride. I can't wait to take it wheeling at Rausch! Wish I did the rear coilover also, maybe in the fall if I can fit it in the budget.
Old 01-18-2015, 12:03 PM
  #44
winkelhawk's Avatar
Old 04-03-2015, 12:25 AM
  #45
winkelhawk's Avatar
Got a few more things done this week. Welded up a Artec truss, installed rear bumpstops and rear swaybar links. 5:13's are going in today and I should be swapping the axle on Friday. Also got Synergy lower control arms, front track bar, drag link, tie rod, sector shaft an track bar brace.
This is for you DBTJKU
Old 04-16-2015, 12:38 AM
  #46
winkelhawk's Avatar
Got my trussed D30 installed over the weekend and added an Evo hi-lift mount, Synergy drag link, tierod, trackbar, lower control arms, and ball joints.
ID:	606593Click image for larger version
ID:	606594Click image for larger version
ID:	606595Click image for larger version
Old 09-24-2016, 02:15 AM
  #47
winkelhawk's Avatar
I haven't posted here in a while.I added an Antirock in the front, it is great! I am going to look at replacing the rest of the control arms soon to increase flex, add the rear antirock, lockers, and a few other things hopefully in the spring. Got to test it out at Rausch a few weeks back, performed great. i did blow up a rear shock though...
ID:	657341Click image for larger version
ID:	657342Click image for larger version
Quick Reply: Tiki Build
