Transfer case exploded
Old Mar 7, 2011 | 06:41 PM
u-joint's Avatar
Originally Posted by dmhines
Wow .. Good Catch. It is installed backwards!
Just out of curiosity, did you install this yourself or did you pay a shop to do this?
Old Mar 7, 2011 | 06:44 PM
cuongdyna's Avatar
It is after market drive shaft made by Reel both front and rear. I bought the jk with the rear shaft installed that way.
holy cow!! glad that you're okay. looking at the pics, i see that you still have your factory front output shaft on and can only assume that you have some kind of adapter or flange mount. if i could guess, this is part of your problem but what's troubling me more is the fact that looking at your rear drive shaft, i could swear you have it installed backwards. at least, i don't think i see a double cardan and i'm definitely seeing the slip shaft and that really should be at the pinion end.
Old Mar 7, 2011 | 06:46 PM
Captain Wild Thing's Avatar
I already had both front axles, ring and pinyon, and transfer case replaced under warranty all from one mud hole. It cost me $50 and a do it yourself car wash. And still didn't get all of the mud out. It took two jku rubis and a f350 to get me out and it was bone stock at the time. So if you need stock gear to throw back on I still have all of mine.
wayoflife's Avatar
JK-Forum Founder
Originally Posted by cuongdyna
It is after market drive shaft made by Reel both front and rear. I bought the jk that way with the rear shaft that way.
really?? well, whoever installed the shaft installed it backwards. if you bought your jeep from a dealership and they did this, i would make them pay for this. you have proof they installed it wrong and, i would bet this is the reason why your t-case exploded.
Old Mar 7, 2011 | 07:40 PM
cuongdyna's Avatar
Maybe the picture was taken at the wrong angle. Just out of curiosity. Why would my rear drive shaft would cause the T- case to fail? Isn't the front drive shaft is connected to the T-case which is attach onto my front differential? The front drive shaft is a after market reel.
I bought the JK from a private party. I didn't buy it from the dealership.
Old Mar 7, 2011 | 07:57 PM
jesse0376's Avatar
Both drive shafts bolt to the tcase. The tcase bolts to the back of the trany.
Old Mar 7, 2011 | 08:26 PM
racin444's Avatar
Both front and rear drive shafts are connected to the tcase as stated above. If you have your rear drive shaft installed backwards then the stress from the single cardan joint is pulling on the tcase instead of the axle. The double cardan acts as a cv shaft. The reason they put the double cardan joint on the drive shaft is to prevent this from happening. Ever notice that your front axles bind when youre turning in 4wd on dry pavement? Thats basically what happened to your drive shaft and the stress from binding blew up your tcase.
Old Mar 7, 2011 | 10:21 PM
TEX-AG's Avatar
wow. Another lesson on what not to do. This is another issue with buying a used modified rig, you have no idea if that person knew what they were doing or not.
