Trashed My Dana 44 Front Axle
Old May 12, 2009 | 02:50 PM
  #31
Muffins's Avatar
Wow, that's pretty serious, but like you said, a great opportunity to upgrade to D60s
Old May 12, 2009 | 04:35 PM
  #32
Trail Bud's Avatar
let me know when you get back together.
Old May 12, 2009 | 04:51 PM
  #33
greenmachine07's Avatar
you have to keep up with mel. just go with 42s
Old May 12, 2009 | 05:35 PM
  #34
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Originally Posted by TeraFlex
ouch. Couldn't of done that in a few months now could you?
couldnt have built them a few months sooner could you? haha
Hopefully in a few months I can afford them
Old May 12, 2009 | 06:18 PM
  #35
wayoflife's Avatar
JK-Forum Founder
Originally Posted by Lo2aY
Good choice on the front
I'm getting D60s for the same reasons! I don't want to blow up my factory axles
I think you can run an adapter for your wheels on the front..
actually, you can't. the hubs require you to have a wheel with a larger center hole.
Originally Posted by .:eMETAL:.
well Mel has run the dynatrac 60 for awhile now and should be able to steer you in the right direction of whether to rawk it or not.
yeah, i've seen what mel has done with his dynatrac prorock 60 and so he was one of the first people i talked to right after the break. ultimately, i do think this is the way for me to go.
Originally Posted by benmar2000
WOW!! That sucks..
I guess you will look kind of strange with a D60 front and a D44 rear..
it's not too bad. i'll have to get wheel adapters for the rear anyways so it'll be good. plus, i'm still running a prototype set of 35 spline superior axles in the rear which is just about a 60 anyway
Originally Posted by joepile
THAT IS ROUGH well no i know i dont wheel as hard as you and will never have that kind of experience so i am glad i never plan on going bigger than 35s
sorry for your loss
honestly, i have said it before and i will say it again, 3" of lift and 35" tires is about the most perfect setup for a JK and there's pretty much nothing that i haven't been able to do with it.
Originally Posted by greenamphibious
that would never happen to a DTURDY that sucks but man if you are gonna break you might as well do it right....
oh boy, did i ever do it right this time around
Old May 12, 2009 | 06:24 PM
  #36
wayoflife's Avatar
JK-Forum Founder
i wish
Originally Posted by jayrav
D60S
These things suck when they happen...but its the perfect excuse I was undecided whether or not I should upgrade to D60s when I go up to 37s with beadlock wheels. This answers my question
Thanks for sharing!
yeah, you can get by for a long time with the dana44's but depending on how hard you play, it'll only last up to a point.
Originally Posted by Warlock13
That's cazy...!!!!!! Now it makes me wonder long term if I want to save for Dana 60s and 37s on the 2 door
honestly, i really do think it depends on how hard and how often you play. as you know, we hammer on our jeep and very very often. i really don't think most people fit this bill. the kind of damage we see is kind of like an accelerated view into the future.
Originally Posted by jkkat
That has GOT TO HURT Eddie. I am very sorry for your loss. And I thaught i has wierd breakage with mine when the stub shaft broke and the axle shaft twisted.
I am sure you will due the right thing and get it done well and more bulletproof.
Makes me rethink going to 37's and glad i do not have beadlocks.
I would almost kind of bet that your tire was on one of them loose rocks then it got spit out and your tire found real rock and BOOM!!!
Kat
the only thing that really hurts is my wallet
as far as how the axle broke, it was pretty much something just like that. boulder rolled out from under the tire and as it came down, found sold traction again and bang!
Originally Posted by deanthemachine04
that sucks wol. like you said though, it is bound to happen eventuallly! you wheel your rig so often and so hard that you have to pay up some time! go to 60's!
oh yeah - in truth, this day was coming for a long time.
Old May 12, 2009 | 06:39 PM
  #37
wayoflife's Avatar
JK-Forum Founder
will do and thanks for all your help that day
LOL!! no way man, mel is concerned that he might break a 60 with them 42's
Originally Posted by planman
I am curious for more details about the break. I have a few questions for Eddie and a couple observations about the break.
It looks to me like either the axle tube was flexing, which put more stress on the shafts and lead to the break, or it was the typical spinning and sudden traction. Was it a spin with sudden traction break or a binding w/flexing tubes break?
if the break had occured on the passenger side, this theory might have held some water but the break was on the driver side - the short side and i just can't see this being the case at all. fact of the matter is, i was playing on a pile of large loose boulders and one just happend to roll out and under the driver side front tire as i was trying to climb up an even bigger boulder. when that happend, the spinning tire dropped and found something solid to bite into and BANG!
I'd also add a comment with regard to the strength of the Superior 5.13 gears. So many have questioned the strength of 5.13 gears in a JK Dana 44 (I was one until David schooled me better), but I don't see any broken teeth in Eddie's picture. This should answer the question about the strength of properly installed 5.13s in a JK Dana 44.
yeah, the gears held up just fine and i never had any problems with them. granted, trail bud blew out his rear 5.13 on metal masher but then, the ledge he was trying to climb was formidable.
Also, in Eddie's profile he doesn't list what kind of U-Joint he is running in his AlloyUSA front shafts. I can't tell if they are CTMs or the large Spicers. If the break is because of a spin with sudden traction, I'd be very impressed if they are the large Spicers (much less expensive than the CTMs). However, if the break was because the tubes were flexing, this would not be as significant. So, what kind of u-joints were you running in your front shafts?
i just have the standard large spicer joints that come with the alloyusa shafts. the ears on the alloyusa shafts are very beefy and look alot like 60's. when the axle broke, i had expected to see it at u-joint as is very common but, seeing a break at the splines is really not that surprising.
I am also curious as to how many miles are on the AlloyUSA shafts. I understand that as metal flexes over time, it will eventually lose its elasticity and break.
A LOT - i probably have close to 35,000-40,000 miles on them and as mentioned before, a vast majority of those are play miles.
I am running 37x12.5x17 KM2s on WE beadlocks on my 2 dr, but I have sleeved and gusseted my front axle, and I am running AlloyUSA front shafts with the large Spicer u-joints. I also have Superior rear shafts and my 5.13s were installed by AEV. Maybe I have a false sense of security, but I think I will be fine for some time with this setup. It will take me 6-8 years before I log 60k miles on my 2dr. I don't hit things as hard as Eddie, and I have a 2dr instead of a monster 4 dr. In any event, if I can get 60k hard wheeling and driving miles out of my D44s before they fail, I'll feel like I definitely got my money's worth.
honestly, i think you will be just fine. just to put things into perspective, you said it would take you 6-8 years to log 60k and i have put that on in just 2 years with it being taken out on the trail at a rate of 2-3 a month. i have been pushing this jeep to the limit and know it and part of that is to really test the products that are on it. also, as you said, i have a 4-door and it is very very heavy. i have no doubts that a 2-door would see a lot less stress. of course, you can't tell me that you aren't going to play a little hard with your wifes new beast of a jeep
Old May 12, 2009 | 07:21 PM
  #38
w.wood jeepster's Avatar
Well, I didn't read all the posts but I feel your pain. I too was a victim of weak rubicon dana 44's.
I've got a rock jock in the front of mine and a built 44 in the rear. I love it I know that ORE is an authorized danatrac dealer, but I love my Currie. Their service is great. You won't go wrong either way. I love the weight in the front. The jeep climbs like a champ. This truly is an opportunity for upgrades, good luck. Hey thats what they make credit cards for/
Old May 12, 2009 | 07:41 PM
  #39
Stuka's Avatar
Thats a pretty good break. And here there are people here that say a D30 is fine for 37's
Throw in a 60 with some 35 spline shafts and get rid of all your worries
Old May 12, 2009 | 11:12 PM
  #40
Lo2aY's Avatar
you know what,, let me check on that.. I just installed my Walkerevens bead locks like 3 months ago I would hate to sell them
let me dig more into it.. If I find anything i'll let you know.. it could save money on wheels
