Old Jan 21, 2012 | 05:24 AM
  #18841
newrm76's Avatar
Installed black and charcoal Iggees seat covers.
Old Jan 21, 2012 | 06:13 AM
  #18842
keith6's Avatar
Just put in my LED dome light and license plate bulbs. Way brighter than factory!!!!
Compliments of superbrightLED's.
I wanted to do this took the dom lite cover off and for the life of me could not get the dome bulbs out I just did not want to break them or screw something up which I am good at do they simply pull forward towards the dash when they come out? thxs much
Old Jan 21, 2012 | 06:36 AM
  #18843
GreenJK07's Avatar
Originally Posted by FlounderKA
How'd you get the dome light cover off?
Stick a flat head screw driver in the passenger side of the lense and there is a small indention. Pry and the lense will flip open and the bulb will be exposed. It will be self explanatory once you look at it. They also have a diagram in the manual.
Old Jan 21, 2012 | 06:41 AM
  #18844
GreenJK07's Avatar
Use a small screw driver on the side of the bulb in the clip. I know it seems sketchy but that's how I did it and they came right out. Pry on one end and the bulb will pop right out and then grab with your fingers. ******FYI-do this after the bulb has cooled!!!!! I burned the sh*t out of my finger when I grabbed the bulb!******
Old Jan 21, 2012 | 06:56 AM
  #18845
MacBeJeepin's Avatar
I added Smittybilt GEAR tailgate pouches, Grill mod, added VDP stubby conversion, took off my side steps, and then added stock rubi rails this morning. Also took out the carpet until I find the leak, and added 4wd rubber mats. Next up making my own grab handles with 550 cord.
ID:	267656Click image for larger version
ID:	267657Click image for larger version
ID:	267658Click image for larger version
ID:	267659Click image for larger version
Old Jan 21, 2012 | 07:00 AM
  #18846
TJM12's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=267656"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=267657"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=267658"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=267659"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=267660"/>
Looks good. Did you use jack stands to get those rails on? Those suckers are heavy.
Old Jan 21, 2012 | 10:38 AM
  #18847
I wish I had some. They're at my father in laws house. So, I put the smaller screw threads through the pinch seem holes, and while supporting with one hand, I put the bigger support bolts on underneath. It only took about 45 minutes in 20 degree weather this morning
Old Jan 21, 2012 | 11:33 AM
  #18848
Scrappyjk's Avatar
Just getting back into wheeling with new 2012 rubi. Added fan fours stubby and warn 9.0rc. Had to drill out new holes for mounting. Also support brackets had to be ground down to fit winch sizing. Did not need to move pump in front for install. But all that being said very happy with results.
Old Jan 21, 2012 | 03:58 PM
  #18849
DillionDay's Avatar
Just finished installing eveything. Sounds really good. The sub doesn't hit as hard as I thought it would. Looks like I will have to fine tune it. I'm too tired and sore to put all the trim back together tonight. Now that I'm done I need a
Old Jan 21, 2012 | 04:06 PM
  #18850
GreenJK07's Avatar
Thumbs up
changed out my PCV valve. Man, its purrs better than a kitty now. Also noticed a drop in my idle. While i was putting the coil pack back on, i decided to look into changing out my plugs & wires as i am at 56k with stock plugs/wires. Highly recommended.
