Old May 8, 2012 | 05:03 AM
  #21551
Shankspony's Avatar
ID:	314254Click image for larger version
ID:	314255Click image for larger version
ID:	314256Click image for larger version
ID:	314257Click image for larger version
in a couple days... Tera flex 1.5" Leveling Kit.
Old May 8, 2012 | 06:43 AM
  #21552
GaMtnJk's Avatar
I installed my new Trek Top NX!
Old May 8, 2012 | 06:47 AM
  #21553
ssg381's Avatar
Painted my exhaust with some high heat paint.
ID:	314272   Click image for larger version
Old May 8, 2012 | 07:10 AM
  #21554
kaptkrappy's Avatar
Ah, I remember doing that. It was the first "mod" to my JK. Makes the giant silver muffler just disappear.
Old May 8, 2012 | 07:42 AM
  #21555
Shankspony's Avatar
I have to repaint mine... a little reddish brown starting to show through. One of the best mods evah!
Old May 8, 2012 | 08:13 AM
  #21556
WrangledBrain's Avatar
Looks awesome, where and what kind of paint should I buy? And is there a certain method to applying the paint? Thanks!
Old May 8, 2012 | 08:17 AM
  #21557
Korsonian's Avatar
Teraflex coil lift over the weekend. Wheels and tires in the way
Old May 8, 2012 | 08:33 AM
  #21558
kaptkrappy's Avatar
I used black grill paint from a wel known home improvement store. 1500 degree temp. flat black, and cheap.
As far as applying it, I laid on the floor and sparyed the muffler, the pipe, and anything that got in the way. My JK was only a couple of days old and very clean under there.
See, muffler gone !
Name:	Rear Close up_.jpg
Old May 8, 2012 | 08:37 AM
  #21559
JRockman's Avatar
Originally Posted by dpowell5523
Have you noticed any left pull in the steering wheel. It a nitro shock, so I figured with the constant pressure to extend that's why I have a little pull to the left now. I had all 4 ball joints replaced at the dealership, new shocks, and an alignment done the day before I put mine on. Everything was good before that.
In fact I specifically put on the single gas shock to try and counter the constant slight pull to the passenger side, which I have for some reason. I didn't really notice that the single shock pushed back towards the driver side. As for your vehicle's pull, you could take the shock off, drive down a side street, and see if it's still pulling without it.
Old May 8, 2012 | 08:44 AM
  #21560
ssg381's Avatar
I used Rust-Oleum engine enamel paint, it resist heat of up to 500 degrees.. and is also gas and oil resistant. 1 can was more than enough. bought it at Auto Zone for $6.00.
