Old May 12, 2012 | 01:25 PM
  #21711
mcarr261's Avatar
Rear diff fluid change, re-greased JKS swaybar quicks, and checked torque on all bolts for suspension
Old May 12, 2012 | 02:55 PM
  #21712
dpowell5523's Avatar
Originally Posted by Stephane87
Just finish the second part of my trunk cover. It's plywood with 2 coats of bedliner, for a total of 40$.......
I see that you left the tailgate bar on from your soft top. Is there a reason for that? Also it looks like this will work even with your top on? Sound like something I would like to do.
Old May 12, 2012 | 04:03 PM
  #21713
Emmeljk11's Avatar
Installed spidertrax 1.5 wheel spacers and cut my rear fenders
Old May 12, 2012 | 04:12 PM
  #21714
jkhooligan's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=315994"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=315997"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=315995"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=315993"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=315998"/>
Nice! I did the same spacers...any issues?
Old May 12, 2012 | 04:40 PM
  #21715
Stephane87's Avatar
"your mail box is full..."
I left it on (tailgate bar) because mine is hard to put on (don't know why). I put the cover on today and I like the result except for 2 things:
1) the 2 square holes next to where the tailgate bar clip to the jeep are to big (if you don't make those holes you will have to take of the plywood panel every time you want to remove the tailgate bar....with the Bestop Supertop tailgate bar).
2) if find out that there's a squicky sound coming from the passenger corner so probably the 2 panels rubbing on each other.
Fit perfectly with the soft top up and down (I will go in 5 minutes to take some pictures with the soft top up). Because of the thickness of the plywood (3/4") and also that I use the original hardtop screws, it will probably not be good with the hardtop (not enough grip from the screws) unless you change the original screws for longer ones.
I can send all the measures that I have so it will make your work easier.
Old May 12, 2012 | 05:23 PM
  #21716
Stephane87's Avatar
With soft top up
ID:	316019   Click image for larger version
ID:	316020   Click image for larger version
  #21717
Sorry about that. I'll go empty it if I can figure out how to on my phone. I would love to have the measurements. I have access to some aircraft grade aluminum so I was thinking of making mine from that.
Old May 12, 2012 | 05:25 PM
  #21718
Stephane87's Avatar
Hum, can you get me some of that???
Old May 12, 2012 | 05:56 PM
  #21719
DyerMkr's Avatar
Default Wash, Bra, Bikini and new JK stickers!
Old May 12, 2012 | 05:59 PM
  #21720
DoinwkJK's Avatar
Installed LED interior lights. So much better!
ID:	316033   Click image for larger version
