Old Jun 18, 2012 | 01:41 PM
  #22921
gimp_dkd's Avatar
Got around to Plasti-dipping the front quarter panels.
ID:	330843   Click image for larger version
Old Jun 18, 2012 | 01:43 PM
  #22922
Hack12's Avatar
That looks great, nicely done!
Old Jun 18, 2012 | 02:47 PM
  #22923
Bubblegoose1's Avatar
Installed my tranny cooler last weekend and just checked the fluid when the jeep was cold. Looks like I overfilled the tranny. I put a half a quart of ATF after the install and now It's reading well over hot on the dip stick and it hasn't been started in a week. Looks like I'll be pumping out some tranny fluid after work to keep my seals from blowing :(.....
Don't trust a cold reading; useless and inaccurate. Check with trans hot, engine running and in neutral. Then look at your hot reading.
Old Jun 18, 2012 | 02:56 PM
  #22924
ronjenx's Avatar
A cold reading is fine, but like Bubblegoose1 said, the engine has to be running. With the engine stopped, the fluid in the tranmission drains back to the pan, and the dip stick will look like the transmission is overfilled.
There isn't much difference if the transmission is in neutral or park. I've checked mine both ways.
Here is a pic of the fluid levels as they relate to transmission fluid temperature.
Old Jun 18, 2012 | 03:23 PM
  #22925
Thanks for the info. Didn't know about the temp readings. Nice
  #22926
ZERO LIMITZ's Avatar
I fill like a little kid at Christmas!!!!! Went home for Fathers Day and a Smittybilt XRC rear bumper and tire carrier, a ARB dual onboard air compressor, A ARB tire deflator kit, and a $250 visa gift card for more mods was waiting for me when I got there... YEA!!!!! Now just need time to install.....
Old Jun 18, 2012 | 03:52 PM
  #22927
GreenJK07's Avatar
Wow! Looks great!
Old Jun 18, 2012 | 03:53 PM
  #22928
GreenJK07's Avatar
Thank you! I figured the cold reading would be off bc I knew the fluid was not cycling. I'll warm it up again and check it hot.
Old Jun 18, 2012 | 03:54 PM
  #22929
GreenJK07's Avatar
Thank you! I'll check it Tom. It's storming right now and I don't feel like running to my garage :(
Old Jun 18, 2012 | 04:26 PM
  #22930
Sinz's Avatar
FINALLY!!! My AEV Heat Reduction Hood came in today, also my RECON LED Signal & Fender Side Markers, The Jeep is at the body shop today because after I installed the Bumpers & Tire Carrier it rained and they got alot of surface rust like it was instantly, I am also going to get the death dimples removed and all scratches repaired while it there, I went to the powder coating shop which happens to be 3 buildings down from the body shop and I decided to do the Bumpers, Rock Sliders & Tire Carrier in a semi gloss textured coating and as for the tail gate cover that will be silver to give it some contrast!
AEV Hood...
Recon LED's...
The Jeep in the Body Dhop with LED Siganals Installed...
LED's On (Regular)
LED's (Blinking I timed it just right to get the pic of them fully on)
The Jeep in the Shop for "Teardown"
I Took the Tire Carrier off and getting all the pieces ready for powder coating...soor for the bad pic
