Old Aug 31, 2012 | 04:56 PM
  #24711
joehunter78's Avatar
Originally Posted by joehunter78
Added 3" lift 5 37x12.50s 4.88 gears and axel gussets
Old Aug 31, 2012 | 05:17 PM
  #24712
bobberdown's Avatar
Swapped the rer radio for the rhb radio for garmin navigation in my 09 rubicon
Old Aug 31, 2012 | 05:53 PM
  #24713
J.cyr8's Avatar
Tramp stamped my JK with a JK!
Old Aug 31, 2012 | 07:18 PM
  #24714
Emmeljk11's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=360651"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=360652"/>
What lift? I have 2011 2dr flame red! I want it like that!
Old Aug 31, 2012 | 08:02 PM
  #24715
kssting's Avatar
Finally got around to making a piece that covers up the gap when the rear seats are down. I was tired of shoving towels into the gap. Now it is a lot more dog friendly.
Old Aug 31, 2012 | 08:08 PM
  #24716
Ooothatguy's Avatar
Looks good can you post more pics?
Old Aug 31, 2012 | 08:10 PM
  #24717
TURTLECON's Avatar
Duuuuude this is EXACTLY what I need for my giant Labradors! Can you post some specs or a brief writeup?
Old Aug 31, 2012 | 08:16 PM
  #24718
robsjeep9's Avatar
JK-Forum Ambassador
My baby was LineX'd .... No more carpets... Smelly ones
ID:	360733   Click image for larger version
ID:	360734   Click image for larger version
ID:	360735   Click image for larger version
Old Aug 31, 2012 | 08:47 PM
  #24719
kssting's Avatar
It was really easy. I used an 8" (actual width about 7 1/2) wide 48" long 1/2" piece of wood that I found at Home Depot in their trim department (10 dollars) and cut the length to fit between the seat belts. It was 39 1/2 long. I also picked up the roll of outdoor carpet (10 dollars) from home depot and cut it to size and used Liquid Nails to attach it to each side of the board. I even sprayed the edges of the wood black before I attached the carpet just to help it blend in. It probably took 20-30 minutes and cost around 22 dollars. The carpet helps blend it in but also provides good traction for my Dane mix.
Old Sep 1, 2012 | 05:10 AM
  #24720
Ricktrr's Avatar
Originally Posted by Ricktrr
I installed a RIPP supercharger which ran well for about two miles. Then the check engine light came on amid the ringing bell. Back to the garage to recheck everything that had already been rechecked. All looked well, and a call to tech support recommended that I remove the fuel control wires from the ECU and return it to stock. I did that and everything ran correctly. Tech support says it has to be a bad wiring harness or a bad fuel control module. They sending replacements and I'll see how it goes then.
I liked the two miles I got out of it before it went south.
Got a new FCM from Ripp yesterday and installed it. Runs like a charm. I'm really more interested in highway performance than off road, as low range provides all I need for off road. It's those steep roads up through the mountains that I hate having to go the third or even second to pull.
Thanks RIPPMODS!
