Old Oct 1, 2012 | 03:14 PM
  #25571
fadeout's Avatar
Added this tonight... Yes it's a 1st gen. I initially broke the welds off of my stock bolts so this seemed useless after I drilled the holes in it and had a Homer moment. So I got to thinking and broke out the dremel and cut a hole for the vent a touch smaller, worked perfect and the old vent fit snuggly back in. Best of both worlds I guess.
Old Oct 1, 2012 | 06:18 PM
  #25572
deaner23's Avatar
finally ordered a rc 1.25 body lift. now i just need to find time to install that and my cb!
Old Oct 1, 2012 | 07:50 PM
  #25573
Dozer7's Avatar
Originally Posted by dpowell5523
Are they from Advanced Automotive Concepts/Oracle Lighting?
Yep good guess!
Old Oct 1, 2012 | 07:53 PM
  #25574
Dozer7's Avatar
Originally Posted by brutusroof
Where did you find those fogs?? I have the JW Speaker LED headlights and having been searching for the perfect fog lights to match.
Oracle is the name I believe.
Old Oct 1, 2012 | 07:55 PM
  #25575
D_engel's Avatar
are you saying the vent is the only thing holding it in? Or did you cut the vent hole so you could get to the nuts in back?
Old Oct 2, 2012 | 02:44 AM
  #25576
Ol' Bob's Avatar
Post some install pics if u would. Probably my next mod. Also if you would show what interior changes it makes (4wd lever, automatic shifter etc).
Hope it all runs smooth for you.
Old Oct 2, 2012 | 03:43 AM
  #25577
dpowell5523's Avatar
Originally Posted by Dozer7
Yep good guess!
Wasn't a guess I have the same setup. How did you like pulling the headlight assembly apart? Mine wasn't that easy. What bulbs are you using with that setup?
Old Oct 2, 2012 | 05:25 AM
  #25578
Bklynborn64's Avatar
Finally upgraded my RES to RHR unit, I was surprised by the navigation display on the EVIC, I did not know it did that, we'll I thought it was cool.
Old Oct 2, 2012 | 05:37 AM
  #25579
fadeout's Avatar
I measured and cut a rectangle so I could bolt it back up and use the vent. I would've just ordered the new version of their tramp stamp but it doesn't work with the vertical vents so I had to improvise a lil.
Old Oct 2, 2012 | 05:51 AM
  #25580
amel22's Avatar
i installed my OME HD lift and this weekend will be the OME SS and JKS rear track bar
ID:	373362   Click image for larger version
ID:	373363   Click image for larger version
