Old Oct 1, 2008 | 09:08 AM
  #2701
JKBenB's Avatar
Originally Posted by SiliconTi
Extended the 4 breather lines. Completely replaced the front, used the old front to extend the rear, and extended the trans/xfer lines. Took some time, but I am now good for deep water.
Where did you extend them to? I'm really needing to do the same now that I have my snorkel on... Don't want a false sense of security, though I'll prolly still check fluids if I get real deep for very long.
Old Oct 1, 2008 | 11:08 AM
  #2702
ARubicon's Avatar
Had spray in bedliner put on inside. love it, no more carpet.
[IMG][/IMG]
[IMG][/IMG]
Old Oct 1, 2008 | 11:15 AM
  #2703
505JK's Avatar
[IMG][/IMG]
[IMG][/IMG]
Did you take of the heat shield/insulation or what ever that crap is on the floor board? I want to do this but I'm not sure if I should leave that in of take it off.
BTW, Looks good
Old Oct 1, 2008 | 11:17 AM
  #2704
tuber's Avatar
Monday night: Brought home new '08 Rubicon Unlimited
Tuesday night: I installed the black Mopar fuel door.
Tonight? Pick up perforated stainless steel for grill mod
Old Oct 1, 2008 | 11:45 AM
  #2705
Hammerman's Avatar
Default Shrocksworks bumper and winch
Good install, most I've seen on winch install the red power wiring are sticking out. Well might be that they like RED
Old Oct 1, 2008 | 11:55 AM
  #2706
Hammerman's Avatar
Default Installed ARB differential
Yep I installed the front cover (RED) changed the lube oil. a bit of advice don't go beyond the 14K miles to change the fluid (diff) I changed the fluid on the rear and it was bad looking (this is normal per Eddie) I even used brake cleaner to clean it out. I looked at the new Differential fluid again, looked ready to change even after using Mobile ! full Syn less than 400 miles. I'll check it more often now that I have a dip stick with a magnetic end. of course unless you would like to replace the gears to 513, and put 35 or 37 tires on the Jeep
Old Oct 1, 2008 | 12:14 PM
  #2707
SaginawMike's Avatar
I "installed" a set of Mopar slush mats in mine today.
Hey. I just paid cash for my Jeep last week so I need some "recovery" time.
Old Oct 1, 2008 | 12:26 PM
  #2708
hntndawg's Avatar
Got me some Rubi rims and tires and order my boost!!
Old Oct 1, 2008 | 12:39 PM
  #2709
ssmathis's Avatar
I installed my Hella 4000's on the stock bumper.
Scott
Old Oct 1, 2008 | 05:15 PM
  #2710
08{GA}RUBICON's Avatar
Default Installed Power Inverter
Installed 400 watt Power Inverter in my storage box!
