Old May 8, 2013 | 02:23 PM
  #31821
lobster86's Avatar
Originally Posted by bob-o
Ya its kinda custom. I'm saving up for beadlocks too that why I spent $200 for spacers so I can get some use out of my stock wheels. Then when I get my beadlocks, I can sell my spacers on here to someone. I figure it would be cheaper to just get spacers instead of cheap wheels that no one would buy after they get hammered from the rocks
Yeah would be the smart thing to do. Do you have any worries of the spacers going out? I've read a few bits on them failing, course I guess everything fails eventually.
Old May 8, 2013 | 03:45 PM
  #31822
dragonkj's Avatar
Originally Posted by rjaranilla
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455515"/>
Actually the install manual for the rocker knockers give you instructions to trim the rear pinch seam for bigger tires. Awesome! Go poison spyder!!!
Could you post up their write up? Is it any different from the one listed on here?
Old May 8, 2013 | 03:56 PM
  #31823
DBTJKU's Avatar
Installed my DirtyDog4x4 net
Old May 8, 2013 | 03:59 PM
  #31824
Bootscraper's Avatar
Installed the grade 8 bolt kit from Northridge. Paranoia got the best of me. Better safe than sorry.
Old May 8, 2013 | 04:04 PM
  #31825
medburd's Avatar
Swapped out the factory headlights & fog lights.
Got some led 7"round universals off of Ebay and found some pl-203w pilot fog/driving lights. Cause its a 2010 I needed to put in relay w/primary juice coming from the battery. I was psyched I was able to get the factory housing to work with the new fog lights. Makes adjusting easy. Way more light across the board.
Old May 8, 2013 | 04:07 PM
  #31826
justanothermoparman's Avatar
If you don't mind me asking, how much does this kit cost?
Sent from my MB855 using JK-Forum
Old May 8, 2013 | 04:11 PM
  #31827
about 50 bucks shipped. Nice kit too. I'd do it again in a heartbeat. Part number is NORGRADE8
Old May 8, 2013 | 04:15 PM
  #31828
Thanks for the quick reply.
Old May 8, 2013 | 04:22 PM
  #31829
bob-o's Avatar
No worries here. I just followed spidertrax's instructions and used the supplied lock tight on the threads and torqued all the lugs to 95ft/lbs, installed wheels, then torqued those lugs to 95 also. Then drove it around for a while and checked the torque on the spacers again and they were good. I have put 22k miles on them so far with 37's and had zero failures
Plus, I usually haul a$$ through the desert, drive up to 100+mph on freeway and take it rockcrawling on the weekends
Old May 8, 2013 | 04:28 PM
  #31830
GreenJK07's Avatar
Received and installed my OTRATTW switches to replace my old rockers and hardware my winch controls. I love them!
ID:	455780   Click image for larger version
ID:	455781   Click image for larger version
