Old Oct 20, 2013 | 09:59 AM
  #35911
GoinCamando's Avatar
Originally Posted by BrowniesJK
Lower gearing.
On what? Low, high or both?
Old Oct 20, 2013 | 10:05 AM
  #35912
Insidejob01's Avatar
High is 1:1 low is 4:1 in rubicon
High is 1:1 low is 2.72:1 in regular
Old Oct 20, 2013 | 10:37 AM
  #35913
kmrtnsn's Avatar
Originally Posted by Marmot mb
4 new Rubicon shocks from a buddies brand new Unlimited Rubicon.
2 new calipers, brake pads and rotors in the rear.
2 new front wheel bearings
I wonder if those hubs could be used in setting up a trailer..........
Old Oct 20, 2013 | 10:42 AM
  #35914
Cedo Nulli's Avatar
Secured downtown Melbourne, FL from the Zombies
Old Oct 20, 2013 | 10:57 AM
  #35915
RealJK's Avatar
Originally Posted by nvglockster
I've been looking at those. Was the install difficult? Did you have to drill or use existing holes?
It wasn't too difficult.. I drilled and tapped them. I took pictures of the install that I can post up if you're interested.
Sent from my SM-N900T
Old Oct 20, 2013 | 11:30 AM
  #35916
Jkrgv's Avatar
No issues with driving with a mini gun?
Old Oct 20, 2013 | 11:57 AM
  #35917
Marshall31's Avatar
Finally got the CB, PA, and Ultramount installed. For a guy who hates doing this type of thing, I am very happy with how clean it turned out.
Strike Force Zebra mount. (Thanks Bill)
Drilled and installed grommet for wiring.
Had to make this bracket to mount the PA. This cheap ($8 on Amazon) unamplified Pyle PSP8 speaker fits perfectly in this spot on 2012. Bracket just keeps it from moving.
Cooltech Ultramount
Because I mounted the CB centered to the vehicle, the bracket hangs signifcantly off to the right of the SFZ mount. During my test fit, I could see the shaking was going to drive me crazy. I reinforced the Uniden bracket with a piece of steel tie. Reduced the shaking to almost nothing.
Old Oct 20, 2013 | 12:01 PM
  #35918
GreenJK07's Avatar
Originally Posted by Cam36
Cake done in an hour. Granted my buddy let me throw it on the lift. But definitely still doable on your back if need be. Only tough part are the two top bolts.
Good! Glad to hear! Thanks for the info .
Old Oct 20, 2013 | 12:31 PM
  #35919
JKRVEE's Avatar
Changed the rear diff cover and gear oil
ID:	506493   Click image for larger version
Old Oct 20, 2013 | 12:40 PM
  #35920
Chevyguy68's Avatar
Used bedliner for the fender flares and the hardtop, to get the color back and hopefully less easy to scratch!
