New rugged ridge Stryker bar and new 2014 Sahara
2007 2 door Sahara, Sprintex supercharger, 3.5" RE lift, full cage, Tom Woods shafts, Synergy sleeves and gussets, 4.88's, RR front bumper, Evo d rings rear, buncha other stuff too lol. 2014 JKU Sahara as well
Easy little mod if you own a welder. Just tacked these little rings (found them in the barn) on top of the factory screws. Dual purpose-makes it into a thumb screw-no tools needed to tighten or loosen and gives an additional tie down location up high. I stand my freedom tops up against the backseat and use an adjustable bungee to attach to these and hold the tops.
Mounted my new rubber (BFG 35x12.5x17 km2's... Have been running this tire for 2+ years) to my new AEV Pintler Beadlocks. Took me about 6 hrs total... Am a bit sore :-)
For all those interested in this rim.. Its a great rim but the bead ring nuts that aev supplies are total crap... They switched to this allen key nut that has a lower profile to - i suspect protect against sheering off the heads. However, the allen key hiles and bolt are too sot and when you attempt to tork correctly the allen hole rounds out - totally useless. I bought stainless bolts and went that route... Awesome and i even prefer the look better.
Also had my new synergy ball joints installed! Good week.
Mounted my new bfg kn2's (35/12.5/17) (got about 55k out of my last set) to my new arv pintler beadlocks. Love the rims. However, the ring bolts arv ships w the wheels are crap - allen key driven... Problem is that they round out and cant handle the proper tork (first to 10lbs, then to 15lbs)... They just strip out. I ended up having to drill 3 out. Switched to stainless bolts and no issue at all... Used dynobeads for balancing... Used the 12oz bag per tire (vs the 10oz recommended by dynobeads) b/c i know how difficult the 35's are and how much lead it took to balance previous set. Balance is great! Low and highway speeds.
Also had my synergy ball joints installed. Great week!
I just had GenRight stinger, rear bumper, tire carrier, rock rails & fenders installed. The Jeep also has the Metal Cloak Game-Changer Suspension Package.
I am trying to win a Jeepers Jamboree Contest to jeep the Rubicon trail in California with Tony Pellegrino. I would appreciate if you could click on the link below to the GenRight Facebook page and like my photo. The Jeep with the most likes wins. We can not let a XJ or TJ win. Thank you so much for your support.
Jim K
https://m.facebook.com/genrightoffro...type=3&theater
Jim K
the hood fluttering on the highway was driving me nuts for almost 6 years lol. Thanks Chris!
