For free, you can make your antenna into a stubby antenna. Just pull the ball off the top of your antenna and cut the antenna to your desired height. Then file the tip of the now shorter antenna and super glue the ball back on. If you choose, you can spray with black spray paint. Worked great for me. Found the idea on youtube.
I dont think you will have to worry about engine heat, most paints can handle a pretty substantial amount just because they are made for outdoor use in the sun. Most high heat paint is for 400-500+ degrees and wont cure properly if not exposed to extreme temperatures. Btw i think the painted vents look badass, ive never seen it before, great idea
I think it looks good like that. I wouldn't add any more though, then it would just look ricey.
Had some dents in my hood from a pecan tree at the house and can't afford a TMD Hood so I decided to make one similar. Daystar hood cowl and raptor lined. Still need to do the vents in silver
