Old Mar 17, 2016 | 09:17 AM
  #45941
sccpdc's Avatar
Changed the grill!
Old Mar 17, 2016 | 09:42 AM
  #45942
Prodigy Performance's Avatar
Former Vendor
Originally Posted by sccpdc
Changed the grill!
Attachment 641005
Looks good!
Just be aware that you now have quite a bit of stuff blocking/reducing airflow to your radiator. If you notice any issues with high engine temps while driving on the freeway in the summer heat while running the A/C, driving uphill, etc., well... you know where to look for the solution. Hold onto that stock grill just in case.
~Jeff
Old Mar 17, 2016 | 11:23 AM
  #45943
N2MWL's Avatar
Installed the EVO quarter pounder w/stinger today..
Also took off that stock tire carrier, EVO gate plate vent is inbound...That should clean up the tail some until I get a different tire carrier back there..
Old Mar 17, 2016 | 11:35 AM
  #45944
mykh11's Avatar
I finally needed tires for my 2011 wrangler. So I decided to put 2 in readylift level kit with 285/70/17 Toyo Open County at2. I also installed Red Rock 4x4 side steps to give it a better look.
Old Mar 17, 2016 | 01:14 PM
  #45945
Milr80's Avatar
Installed extended door pins and drilled the mirrors.
Old Mar 17, 2016 | 01:35 PM
  #45946
OSkullivan's Avatar
Originally Posted by Milr80
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=641022"/> Installed extended door pins and drilled the mirrors.
Extended door pins is a new concept to me. Why are these installed (or what are they for?).
Thanks
Old Mar 17, 2016 | 01:48 PM
  #45947
JeepRubi11's Avatar
Yea I was wondering the same thing. What's the point of the extended door pins?
Old Mar 17, 2016 | 02:29 PM
  #45948
BlackRockBurner's Avatar
Originally Posted by OSkullivan
Extended door pins is a new concept to me. Why are these installed (or what are they for?). Thanks
Long pins make it easier to place doors once removed. Others use plastic over the original pins as guides.
Old Mar 17, 2016 | 05:10 PM
  #45949
JeepRubi11's Avatar
Really.....I replace my doors at night, and it's basically pitch black with no problem at all. I guess they make everything for our jeeps.
Old Mar 17, 2016 | 05:12 PM
  #45950
JeepRubi11's Avatar
Originally Posted by N2MWL
Installed the EVO quarter pounder w/stinger today.. Also took off that stock tire carrier, EVO gate plate vent is inbound...That should clean up the tail some until I get a different tire carrier back there..
Looks nice man. What size tires are those? Are u lifted at all?
