Old Apr 21, 2009 | 05:47 AM
  #5251
allterrain's Avatar
Painted my ProComp 7289's flat black last week while on a road trip to SoCal.
Ahhhh... much better!
Old Apr 21, 2009 | 07:18 AM
  #5252
bcjeep's Avatar
Originally Posted by xblack08x
I like the light bar! How much you charging?
Me too, I would definitely buy one
Old Apr 21, 2009 | 03:04 PM
  #5253
BlueAlgernon's Avatar
Default lock box
This box is the "Gun Guard" by Plano. Here is a link to a site to get one... http://www.exploreproducts.com/plano...safe-12306.htm It comes with instructions and templates for mounting it in your house. You can bolt it down as a safe so no one can just take it and your valuables out of the house. If your in law enforcement these can be bolted together as a locker system so when you enter a holding area you can put up your gun take the key and keep the gun from inmates. I took the little plastic vent off the back door (under the stock tire rack) I have no tire rack back there now so it was easy for me. It has holes all over for mounting and to keep water out I plugged them with a few plugs I had (I need one more from Lowes, look close at the pic you can see the missing one) I drlled 2 holes as per the template used 2 bolts I had to bolt it to the inner wall of the rear door ten replaced the black plastic vent and installed the foam inside the box. The box has foam and double sided tape, it comes out easy (don't rip it) install the bolts then reinstall the foam. Put your valuables in there lock the door, shut your rear door and lock it and walk away from your topless baby knowing your valuables are safe.
Old Apr 21, 2009 | 04:39 PM
  #5254
BIG JOHN's Avatar
My OME HD lift with adjustable front/rear track rars arrived today!!!!!!!!!!!!
Sonny and I will install it this weekend.
Picks will follow!
Old Apr 22, 2009 | 03:28 PM
  #5255
silvurback's Avatar
drilled mirror mod
took the fenders off for a little extra room
Old Apr 22, 2009 | 04:44 PM
  #5256
4JEXEP4's Avatar
Default Drilled door handles.
I finally got around to drilling my door handles.
Old Apr 22, 2009 | 04:50 PM
  #5257
Robar's Avatar
Do they whistle ♪ ♫ ♪ ♪♪ when you go down the road?
Old Apr 22, 2009 | 05:52 PM
  #5258
4JEXEP4's Avatar
Thankfully NO.
Old Apr 22, 2009 | 06:36 PM
  #5259
are their any aftermarket available door handles? i havent seen any and thats probably my only qaulm with the new jk's, lame ass door handles, lol
Old Apr 22, 2009 | 06:40 PM
  #5260
Piginajeep's Avatar
www.offroadevolution.com
sells billet handles
