Old May 6, 2009 | 02:43 AM
  #5411
tunes's Avatar
Default BDS 4.5 and BFG KM2s
Here it is. 4.5 inch BDS
Yukon 4:88s
37 inch BFG KM2s
and swapped the superwinch for the warn powerplant
Old May 6, 2009 | 03:37 AM
  #5412
jayrav's Avatar
Yukon 4:88s
37 inch BFG KM2s
Very nice rig!
Old May 6, 2009 | 05:12 AM
  #5413
evanyj350's Avatar
Got the KCs mounted up. 130W Long Range Driving lights. Mounted a switch in the left dash and wired them up with the supplied harness. Pulled 12v off the cigarette lighter for the feed. Only had to bring one wire in thru the firewall. Took about two hours start to finish. They work great. Very bright. Can't wait to try them out on the back roads around here.
Old May 6, 2009 | 07:41 AM
  #5414
STUPIDFACE's Avatar
Installed my trektop......
And did this to my wheels....This is the worst one...
corey d
Old May 6, 2009 | 07:45 AM
  #5415
pastorsteve's Avatar
How do you like the top? Mine came in Monday but I haven't gotten the hard top off yet to install. Easy installation?
Old May 6, 2009 | 08:02 AM
  #5416
STUPIDFACE's Avatar
Easy to install, but i dont like the way it has velcro to keep it tight (in front above the front seats). It needs some straps to pull the driver and passenger side together to keep it tight. I dont know if i have the older version or what, but it gets loose pretty quick. If best top cant help me, ill probably bring it to an upholstery shop and have some straps sewed on. I like the way it looks though.
corey d
Old May 6, 2009 | 08:30 AM
  #5417
brandonbooth's Avatar
corey d
that seems like you might have the old top... I dont know that it is different in the 2 door from the 4 door but mine has a strap that takes the top on the driver and passenger side in the middle of the door and pulls it together... only problem I am having with it is that it leaks pretty bad at the seam above the sound bar. If the rain will stop here at some point I would love to try to seal it up but for now its a towel above the sound bar keeping me dry. Which actually isnt that bad because it dampens noise from the top flapping against the soundbar.
Old May 6, 2009 | 08:42 AM
  #5418
STUPIDFACE's Avatar
What keeps the straps tight? Do you have any pics of the straps?
corey d
Old May 6, 2009 | 09:35 AM
  #5419
bbinokc's Avatar
Originally Posted by bodybrdng
What was done to my jk this week...... I got my jk this week
I got my JK last week. Wheels, Tires and Lift today! Woo hoo!
Old May 6, 2009 | 10:45 AM
  #5420
corey d
I dont have a picture of it at the moment and I am heading to a concert tonight so wont be able to post a picture of it tonight I dont imagine what it looks like is there is an extra triangle about 6 inches that wraps around and has a strap that is sewn onto it.. and the other side is the buckle which wraps around the door surrounds and then connects to eachother... if that makes any sense... i will see what I can do about getting a picture for you.
Here is one I just found online.
