Whinch mounting with stock bumper
I know theres alot of guys out there running winches mounted on top and inside of the stock bumpers. Lets see these setups.
My Sahara with the Champion 8000# winch plate, roller fairlead, and snatchblock for $299.00 at Cosco.
It's a funky feeling to take a sawzall to your brand new Jeep bumper
Yes, the plate that came with it mounts to both sides of the frame with 3 grade 8 bolts on each side. I had to drill one more hole on each side (it eats up drill bits if you plan to do it.) The frame is very think in that space. GOOD LUCK
i drilled four frame holes two holes in the winch plate and it's still just as good as it was when i started.
