who is part of the 37 in tire club..(post pics)
Old 09-18-2015, 10:04 AM
  #3841
2015WhiteRubi's Avatar
Originally Posted by Slow_but_Sure
Thanks, im very happy the way it came out.
What all did you have to change? Trackbar? Driveshaft? I am new to the JK but just purchased the Teraflex 3" lift with flex arms. Plan on putting flat flares on it so I would have the clearance for 37"s
Old 09-18-2015, 02:14 PM
  #3842
Slow_but_Sure's Avatar
Coast 1310 Driveshaft both
Synergy Trackbars both
Synergy Track bar raised brackets both
Synergy Drag Link
Synergy Tie Rod
Fox ATS Stabilizer
Synergy Ball joints
Reid Knuckles
Chromoly u- joint shafts both
Prorock 44 front axle
EVO rock stars.
I think i should do a build thread, right?
Old 09-18-2015, 06:49 PM
  #3843
Wrangeler X's Avatar
Just got my MTR 37's with 3.5 RK
ID:	624863   Click image for larger version
Old 09-18-2015, 07:17 PM
  #3844
Originally Posted by slow_but_sure
coast 1310 driveshaft both
synergy trackbars both
synergy track bar raised brackets both
synergy drag link
synergy tie rod
fox ats stabilizer
synergy ball joints
reid knuckles
chromoly u- joint shafts both
prorock 44 front axle
evo rock stars.
yes!!!
Old 09-19-2015, 06:17 AM
  #3845
nhk19's Avatar
Coast 1310 Driveshaft both Synergy Trackbars both Synergy Track bar raised brackets both Synergy Drag Link Synergy Tie Rod Fox ATS Stabilizer Synergy Ball joints Reid Knuckles Chromoly u- joint shafts both Prorock 44 front axle EVO rock stars. I think i should do a build thread, right?
I'll ditto this. YES! This wasn't your first rodeo at building a jeep was it? Either that or you had an experienced friend's help. I personally would not be able to cherry pick components like you did to do a build. Again, I'm envious of your JK and your knowledge to do this.
Old 09-19-2015, 10:57 AM
  #3846
JayswranglerX's Avatar
37"x12.5"-17 Nitto Trail Grapplers.
Lift is combo:
Synergy 4.5" front springs, 3.5" rear
Fox 2.0 IFP shocks
Metalcloak Arms(8)
Thank you
Looks perfect...did you do the 3.5's in the rear to avoid any rake?
Sent from my SM-N920T using JK-Forum
Old 09-19-2015, 07:31 PM
  #3847
Dlampe's Avatar
I have my Mastercraft 37's mounted but couldn't get them all balanced today. However, the two we did balance took a lot of lead. One was 5 ozs and one was 10 ozs. How much is too much on a 37?
Old 09-20-2015, 06:36 AM
  #3848
jackoskate's Avatar
Old 09-20-2015, 08:24 AM
  #3849
drtyrat30's Avatar
I had my 37" MXT's balanced on a Road Force computer balancing machine. The worst one witch will be on the tire carrier spare was 4.5oz but the others average 2oz one was less that 1oz. I think balancing 37" is hit or miss but 10 oz sounds high.
Old 09-20-2015, 10:42 AM
  #3850
jknit's Avatar
I've got a 4.5" synergy going in, seems like everyone goes 3" in the rear did you ever have 4.5 in rear or did you do 3" from the beginning?
Quick Reply: who is part of the 37 in tire club..(post pics)
