who is part of the 37 in tire club..(post pics)
#3901
So I have read so much about if you install 37" tires that you must upgrade the Rubicon front differential housing or add sleeves/gussets. How many people here actually do this ? I have my AEV 3.5 lift installed and am looking hard at the RSE fenders that would give me the needed room to run 37" tires but am worried that the stock 44 will not last. I'm building this as a trail rig not a rock crawler so should I worry so much about damaging the front differential ?
#3902
You'll be fine. Everyone thinks these front housings are made of glass.
C-gussets & sleeves are cheap. I wouldn't worry about the front end for regular trail riding like you described. You'll wear out your stock steering components quicker so that's something to be aware of that.
But remember anything can break, just wheel smart.
#3903
#3904
It's very subjective as there's a lot you gotta consider. Some wheel built 44s and blow them up, others go years with out issue so it all depends. I've been running 37s for the last 25k miles and i have upgraded to everything synergy from the very beginning. All I've done to my rubi axles is gussets and a hd artec track bar bracket. Stock balljoints are still tight surprisingly, it's all about how you wheel I choose to pick my line and avoid wheel spin but I'm not easy on them. These axles aren't made of glass like everyone seems but they're not bulletproof either.
I live right next to AEV and talk to the guys all the time. They say it's very rare they see issues with their Jeeps being used as they're designed in the overland arena.
I'm sure bouncing off rocks is a whole other thing...then yes, I'd be upgrading for sure
Sent from my SM-N920T using JK-Forum
#3905
Thanks for all the replies. I guess it's going to come down to garage height, that's why I went with the 3.5 AEV to begin with. Living in my area I need to keep it in the garage if I want the Jeep to stay somewhat nice.
After my lift and with stock rubicon tires it looks like I have 7"s of clearance left to work with. If I go 37" I think I will go BFG since they run a little shorter than most plus they only weigh about 2 mores lbs than the 35" duratracks I was looking at. This would probably put me slightly more at ease than some super heavy Toyos or similar.
I know in the end it comes down to how I drive and living here in IL means my only real off-road is when I take vacation. Thanks again for the thoughts.
#3906
#3909
#3910
