Would this work.... "oil pan skid"
I have 3 sheets ( 2- 30x30, 1-23x23) of 1/4 inch sheet metal and would like to make an oil pan skid. I was thinking of making a box and bracketing it to the undercariage, but do not see the possibility without using the bolts surrounding the oil pan. I dont want to mess with those because i'm assuiming there is a gasket. My thought is, cutting pieces (L x W) of oil pan, possibly doubling the plates and securing them with JB weld or some other type of adhesive. My question to anyone who reads this and can offer help, is this worth doing and wise ? Thanx in advance..
it's pretty much the same thought
I've heard of people doing the same thing. I think one guy even used another oil pan off of a truck that was bigger than the jeeps. I would say it should work well. You really don't contact your oil pan much, but if you do, you can ruin it. I'd say it's a good idea.
Gotta get in on this because I need a skid too. My jack has made contact with the oil pan before
They sell the skids for not that much and they are fully functional and strong. Last time I checked, the rancho one was like $150.
I have work these next couple weekends. But if you get enough good ideas here then I can zip up there for a day and we can get 2 of these built.
No Oil Pan Gasket
I just bought and installed the Benchmark-Designs oil pan. There was/is no gasket. RTV is applied between the oil pan and the engine block.
That makes it a pain to remove the oil pan. You have to cut, and pry, and scrape to get the pan off after you have removed all of the bolts.
