Xenon Narrow flat fenders Installed
Looks great. I will be interested to see how well the LineX holds up on yours. I used it on the bottom side on mine and it is coming off. Maybe mine did not get prepped right. No big deal on the underside though. It is black and you can't hardly tell the difference.
Again, it looks great.
Sam
Sam
I installed mine this past weekend, as Sasquatch posted the instructions have very poor blk and wht pics. Also the 1/4inx20x1in bolts listed on the instructions were non-existant in the kit. You need these 1in bolts to install the frt flare where the support goes. Do yourself a favor and go ahead and get them beforehand and not wait like I did and have stop in the middle and go to the hardware. You'll need a total of 6 (3 per frt flare) of the 1in. The 3/4 ones they supply work fine for the rest. You'll also need two teeniney bolts and nuts (as the instructions say not included) for your side marker light ground wire. When you get your flares in take the marker lights out and look at the size of the hole. What size dunno but it's real little, I'm gonna hook mine up later. You'll also need a 25/32 drillbit. It' a little bigger than 3/8in. the rear holes will need to be drilled except for the 2 holes at top .I installed my frt liners after trimming per instr. (use tin snips,alot easier than a razor) but didn't do the rear. I can see having the extra protection against splashing and such in frt but to me the rear is not worth the hassle of putting it back in. I used 3m rubber undercoating on all the white showing frt and rear. Also when removing frt their are only a couple of bolts to take out that hold the liner to the fender bracket, take those out and just pull real hard on the rest. The rear, no bolts , grab the liner and pull and rip, then grab the flares and yank off. The rears came off in about 30 secs a piece when I realized brute force was better than trying to pry them neatly off. Wife is sick so I don't have any pics, but to me their BADASS. Hopefully get some up in the next day or two. also be carefull and take your time with the rivet tool (for the rear flares only) because it barely lasts through the number of rivets you install. Hope this helps. Mark P.S. Needlenose pliers are needed to hold some of the nuts in place to get them started on the frt. unless you have itty bitty fingers.
what size tires 37's or 35's ? Hard to tell with the new fenders............
