Are you running 33's with no lift?
Old 07-08-2012, 06:03 PM
lre
lre's Avatar
Default Are you running 33's with no lift?
I am about to put 33's, actually 305.75r16's and am going to wait to lift it. If you are running this setup can you post some pics? I would like to get an idea of what it will look like. If you have a shot from the front I'd like to see that too so I can tell how far past the fenders the tires will stick out, if they do at all. Thanks.
Old 07-09-2012, 04:29 AM
20JK10's Avatar
Are you going to be using them on stock wheels or aftermarket? You will need spacers if stock. They will stick out about 2". You will also rub them on your plastic front air dam, I would just remove it.
Old 07-09-2012, 04:52 AM
JE8154's Avatar
305/70r16 duratracs on 16x8 procomp 7089's 4.5" back spacing.
Old 07-09-2012, 04:55 AM
SWAMP RAT's Avatar
I'm running 285/70/17 on stock rims with 1.5" wheel spacers. Will try to post a picture later.
Old 07-09-2012, 05:00 AM
IRE
I will try and post some pics of mine tonight, Saturday I just installed a set of 295/70 R 17 Duratrac on AEV Pintlers. I think I am going with 2.5 lift, not to big on the cut fender look.
JE8154
Do you have the leveling kit on your jeep? Your front end does not look lower then your rear, mine on stock suspension you really notice that the front end is lower.
Old 07-09-2012, 05:03 AM
tymonster's Avatar
33x12.5 Dick Cepek FC-II
17" Rugged Ridge Satin Black, 4.75" back spacing -12 offset
no lift
pictures don't really do justice on it's stance. really happy with it.
ID:	339036   Click image for larger version
ID:	339037   Click image for larger version
ID:	339038   Click image for larger version
Old 07-09-2012, 07:52 AM
lre
lre's Avatar
Aftermarket wheels. Most likely procomp 7069's. I haven't checked yet. Do they come with different back spacing measurements ?
Old 07-09-2012, 08:38 AM
JE8154's Avatar
Originally Posted by lightningsti
IRE
JE8154
It was on the stock suspension at that point but sitting on an incline so it might just be an optical illusion. It definitely had some rake to it. Even more noticeably so now.
Old 07-09-2012, 10:35 AM
mattymo's Avatar
33's stock no lift, no spacers.
Old 07-09-2012, 10:42 AM
HannibleMP's Avatar
Used to run 33's with no lift/spacers
Quick Reply: Are you running 33's with no lift?
