15 month deployment help...
Old Aug 4, 2008 | 11:28 AM
WRAITHYJEEP's Avatar
CHRYSLER SHOULD STEP UP TO THE PLATE AND OFFER SOMETHING FOR SITUATIONS LIKE THIS
ok
on that note
I could go on and on about the things you should have done before storage
so i'll make it short so that the next person knows
1 put the axles on the jack stands so weight is on suspension, as it is designed to be
and that way tires don't flat spot
2 add fuel stabilizer in the fuel
3 fresh oil and filter
4 moth balls around the engine compartments and sprinkled underneath
5 turn vents to recirc
6 put a spacer between wipers and windsheild
7 a breathable cover, birds and other contaminates spiders do poo in warehouses
8 plug intake with steel wool
9 plug exhaust with steel wool
10 disconnect battery hook up a solar panel battery charger
11 drop tire psi to half of stock
ok post storage recovery
1 undo all the above
2then drive that gas out
3then get fresh gas
4oil change
5short trips first
6then longer trips
7park it in the same area and note that the gound is not contaminated by dripping fluids when parked at night
8then recover in morning and check for drips
seals can dry out and harden up
9give ur wipers a tap they will be stuck to windsheild and u will need new ones
thats all i have time to go to work cya
and thanx
