20 min and 20 dollars
Old 10-01-2012, 11:14 AM
Jakejk's Avatar
Default 20 min and 20 dollars
Just metal lath from Home Depot and any color auto pain from a auto parts store. Cut and place.
ID:	372995   Click image for larger version
Old 10-01-2012, 11:21 AM
scott franklin's Avatar
Looks great. What did you install them with?
Old 10-01-2012, 11:38 AM
Jakejk's Avatar
If you cut it to size going from outside hole to outside hole then top to bottom and cut around the tabs that hold the grill in place to where the bottom rests on them, you can just put ur grill back on and it just pushes the mesh right up against the holes, look better then the pic. I'll get a diagram up of how to do it soon.
Old 10-01-2012, 11:42 AM
JK JAGS's Avatar
Uhh, so no fasteners I've seen similar mods put they liquid nails zip tie tabs for assurance.
Old 10-01-2012, 11:52 AM
Jakejk's Avatar
If u want to you can its just however you can get it up mine worked without doing it, just trial and error. Whatever works for u
Quick Reply: 20 min and 20 dollars
