2007 JK problems?
Old Oct 22, 2010 | 11:27 AM
mcdoogz's Avatar
1 Check for signs of water leaks, and since only one top will be on get the dealer to agree to fix any issues with the other one once you switch them if they say both don't have any leaks.
2 Check for the steering clunk - leave it idling for a few minutes to heat it up before driving it or spend some time in stop/go traffic.
3 Start it up a few different times to make sure it doesn't have the random'no start' issue.
4 Make sure you get 2 keys - they are expensive to replace.
5 If it's a Rubicon, make sure the e-lockers and sway bar disco work.
6 If the soft top is on it currently, check the rear-window zippers are smooth and pull easily.
Any scrapes underneath or scuffs on the sidewalls could be signs of off-roading, but don't avoid it just because it's been off road - that doesn't give any indication of how it's been maintained.
Old Oct 22, 2010 | 02:25 PM
crwood1's Avatar
Default 2007 unlimited rubicon
If it is a rubicon, Only problem was the rear locker--locked and would not unlock--check the swaybar unconnect-connect and both lockers several times--lockers are an expensive repair--I have 70k on mine and that was the only problem which Chrysler fixed under warranty--an excellent machine-CRW
Old Oct 23, 2010 | 04:53 PM
07XMan2Door's Avatar
Originally Posted by jharpphoto
I'm going to see/buy an 07 JK tomorrow w/37k miles, manual trans,w/hardtop for $19K. Are there any issues I should be concerned with, things I should be paying close attention to before I plop down my $$$? It looks like a good deal so of course I'm wary. What says the JK hive?
No problems here. Just good times. Talk em down a grand & get ready to put your perma grin on!!
Good luck.
Old Oct 23, 2010 | 04:56 PM
blazenjeep's Avatar
48,000 NO PROBLEM HERE BUY IT...
Old Oct 24, 2010 | 06:24 AM
jharpphoto's Avatar
I checked out that JK today and I'm on the fence. It looked pretty nice but I noticed that on the undercarriage the drive shaft seemed to have a lot of rust (pretty much completely rust covered. Is that normal? There wasn't any rust anywhere else on the car but that concerned me. Am I too picky?
Old Oct 24, 2010 | 07:13 AM
I've never seen a drive shaft that wasn't rusty, other than ones that guys have sanded & painted themselves.
Old Oct 25, 2010 | 08:39 AM
Christine's Avatar
I bought my 07 Sahara in January. It only had 9K miles on it. I did get the Auto Trans recall, but I just added a tranny cooler. Other than that, no problems in the last 3k miles.
