2012 Auto Trans overdrive
Wondering if anyone knows whether there is an overdrive over-ride on the new auto transmission. On my '07, there was an O/D off button near the shifter. Definitely was needed when doing highway driving in mountainous areas or when towing. Don't see a way to turn off overdrive on the '12 auto.
i would normally disable the O/D in first or second...
and then if i get to third and the time is right...
i pop the button so i can then slip into fourth...
edit...having said that...
i think if O/D is disabled at the start...
the trans will rev out longer in the first 3 gears...
seems like that in mine anyhoo.
I tested this out tonight. If you downshift to 4 with the "autostick" it will stay out of overdrive but shift automatically like normal through 3, 2, 1. I started and stopped through several traffic lights and got up to 55 in between. So it seems that the "gear" you select is the highest it will go into but still downshifted as necessary.
This all makes me wonder if it will work to start in a higher gear in low range??? Seems it could be useful sometimes when in low to pick a higher gear to control wheel spin... Ill have to test that later. Darn computers!
